Question about Magellan Triton 300 Handheld GPS Receiver
Frozen gps magellan triton 300
My Magellan triton 300 handheld gps froze, how do I fix it?
  • Anonymous Jan 28, 2009
    after updating to the latest firmware and vp software the unit displays only the shell but unresponsive to any key clicks. Also USB not recognized now.
I have a Triton 300 for 4 years, it died about 2 years ago, as in it wouldnt boot past the triton/ magellan screen, so it remained a paper weight in my junk for 2 yrs until today. This is how I got mine to work. You can try this at your own risk, I will not be responsible for any damages to your GPS. I figured mine was dead this long what the heck. I connected it to my laptop, boot into so called programmer mode, or what ever. I did this by holding up key, back light key and power. Took a few seconds but did boot to this different mode. It should have showed as a USB device but instead showed as a Hard Drive in under my Computer, devices, named H:TFAT, i right clicked it then it showed the same options as a HDD. Check Disk, Defrag Etc. I said fook it and hit check for bad files, it did, then it said device should now work dissconnect and power up. IT POWERED UP :). First time in 2 years, but it is working and I lost nothing on my unit. Hope this may help someone else. Thanks for reading.
Posted on Jan 09, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
The problem is being caused by a corrupt file in the internal memory. This requires a service repair to find and remove the file. Try the Jungle Ghost at jungleghost.com. They do repairs.
Posted on Sep 06, 2010
Magellan triton 400 serial number
The serial number for the Magellan Triton 400 is located under the battery compartment cover
Dec 26, 2012 | Magellan Triton 400 Handheld GPS Receiver
Magellan gps Triton 300 series Jamed up; Reads when turned on ; Internal Error Your Triton has encountered an unexpected error and must shut down. Please wait while your data is saved.
The problem with your magellan triton is that there is a file missing in the support file that allows the triton come on properly hereby leading it to jam.
The solution is for you to get your triton connected to a computer, then you back up the software on the computer, format the triton then you restore the software and maps on the triton. Then your triton will be in good condition once again.
Hope this information helped.
Jan 03, 2011 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton, continues to get fatal application error. What can be done to correct this situation?
Your problem stems from a corrupt software file in the internal memory of the GPS. Unfortunately, the problem is too complicated for you to solve. I really do not know of any people beside Magellan that repair the 200. The Jungle Ghost repairs 300 400 500 1500 and 2000's and maybe he can help you out. Check with www.jungleghost.com
Aug 23, 2010 | Magellan Triton 200 Handheld GPS Receiver
Magellan Triton 300 giving Fatal Application Error!
This is a problem with the internal memory files. They have been corrupted It is too complicated to fix yourself. If the is out of warranty, the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml has a repair service.
Jan 20, 2010 | Magellan Triton 300 Handheld GPS Receiver
Frozen Magellan
Big problem .. you had a bad firmware download and the unit is now stuck in the development mode. Two solutions .. 1) return to Magellan for a replacement. 2) If not in warranty .. there is a third party repair center on the internet .. use your browser and search for 'magellan triton repair'
JG
Oct 12, 2009 | Magellan Triton 500 Handheld GPS Receiver
I need help changing the time zone on my magellan triton 300... I need help even getting to where you can change the time zone
Assuming that you have the latest firmware installed ..then do a MENU>>VIEW>>SETTINGS .. no scroll using your down arrow so the screen shows you the HIDDEN settings and you will see date and time. The rest is easy.
Aug 07, 2009 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 300 instruction manual
The site has pdf files of the manual, Can also be found at a couple of other places on the web.
Apr 29, 2009 | Magellan Triton 300 Handheld GPS Receiver
Magellan Triton 300 GPS handheld
This problem is caused by two possible problems. First go the MENU>>VIEW>>SETTINGS>>MEMORY and CLEAR YOUR MEMORY. If does not work and the unit is NOT seeing any satellites in the satellite screen, then you most likely have a defective GPS+ANT. Unfortunately, this is a part of the motherboard and cannot be repaired.
Mar 19, 2009 | Magellan Triton 300 Handheld GPS Receiver
Magellan triton 500 freezes up
You might have an sd card inserted that contains information that the unit doesn't recognize. This happened to me when I tried to fudge some old magellan destination maps onto the sd card...the format was wrong and the unit froze...gave me the message.
Mar 06, 2009 | Magellan Triton 500 Handheld GPS Receiver
Magellan Triton 300 Handheld GPS Receiver Logo
626 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
