Question about Prestige Appliances Kitchen Appliances - Others
How do I remove the lid on my Prestige 54877-C kettle?
Model no. 54877-C. The lid is failing to stay shut when switched on.
SOURCE: Cordless Kettle
There isn't a part available, cuisinart are horrible for parts, hence I will never buy anything from that company again.
Posted on Apr 25, 2008
  • 18 Answers
SOURCE: Where can I find a replacement lid for Cuisinart Kettle CJK-17BC?
You need to talk to Cuisinart (follow this link to their contact us page http://www.cuisinart.co.uk/contactus.asp?menuId=20)
There is no harm in asking. I have had replacement cooker nobs, bin lids allsorts by just being honest with message and asking nicely.
But if all else fails EBAY =P
Posted on Mar 01, 2009
SOURCE: kettle wont switch off
Lid probably leaking steam
Posted on Mar 26, 2009
co7196
  • 3433 Answers
SOURCE: Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Posted on Sep 13, 2009
  • 1739 Answers
SOURCE: Hi Is it possible to buy
Replacement parts for Russell Hobbs kettles are available here:
http://www.directpartsandproducts.com/russellhobbs-kettles-c-55_1111_1212_1229.html?osCsid=5kjs46s0g583p8ljos3hp0pa41
I don't see your model so would suggest you contact then through their website:
http://www.directpartsandproducts.com/contact_us.php?osCsid=5kjs46s0g583p8ljos3hp0pa41
Posted on May 03, 2011
We purchased a kettle from Tesco model number 20460 and unfortunately the lid will not stay closed.Can a replacement lid be provided.
The model number you listed is not a Tesco model but a Russell Hobbs Buckingham 20460 Kettle (1.7L capacity in Brushed Stainless Steel). You can get Russell Hobbs kettle spare parts from here https://uk.russellhobbs.com/parts-accessories/kettle-spares/ The model 20460 kettle is listed, but I did not see any spares offered.
Sep 13, 2017 | The Kitchen Appliances - Others
How do I fix the lid.
Maybe It is physically damaged, and there is a very slight chance of getting it fixed. Better try the new Hamilton Beach 40880 version. Usually, Electric kettles don't last more than a year if you use it regularly.
Best Electric Kettle Guide Reviews The Grand Kitchen
Jul 21, 2015 | Hamilton Beach 40870 Electric Kettle
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
Jul 12, 2013 | Applica Black And Decker Cordless Electric...
How to fix a kettle when the power switch switches off before boiling point?
There can be several causes. In many cases the power switch is thermo or current tripped, It is like a thermo circuit breaker.
The power switch itself may have to be changed.
The element is pulling too much current.
The thermostat may be defective.
Contact the manufacture to find out where you can buy spare parts to try. You will require the proper connectors, and crimp tools to work inside of these. Also, you will require a sound knowledge of how these appliances work, and the safe way of servicing them.
Because of the way you asked the question, I would think you are not familiar with how to service these devices. I would suggest to give the kettle to a service rep, or to purchase a new one. There are safety issues when servicing appliances.
Jerry G.
Jun 24, 2012 | Prestige Appliances Prestige Pf Enamel...
Mar 01, 2009 | Cuisinart CJK-17BC Cordless Electric...
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Boils continually
much simpler solution: if the filter is not installed, is not installed correctly, or is ripped, the kettle will fail to shut off. also, this model has a lid that must be set down very tight; any leakage around the lid will allow steam to escape, and will cancel the auto shut-off.
the filters on these kettles are a very weak spot in the engineering of the product.
Jan 22, 2008 | Kitchen Appliances - Others
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Cordless Kettle
Jun 23, 2007 | Cuisinart CJK-17BC Cordless Electric...
Kitchen Appliances - Others Logo
169 people viewed this question
Top Prestige Appliances Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Prestige Appliances Kitchen Appliances - Other Expert? Answer questions, earn points and help others
