Question about Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher not working
The water wasn't coming into the machine to wash the dishes or draining out. The repairman came and said it needed a new valve. The valve drained out the standing water, but, the machine still didn't work. He said it needs a new motor. We are debating if we should buy a new one or have it repaired. We have owned it for 8 years and 4 months.
Will be buying a new machine, since we found out their lifespans are between 8-12 years. Don't want to keep on sinking money into fixing the machine or asking for advice.
Posted on Jan 03, 2009
Water fills the bottom of dishwasher, lower spray arm still seems to turn/spray but no movement or water coming out of uppoer spray arm. We took apart the lines to see if there was blockage -- none.
If there is no blockage, your pump may need to be rebuilt or replaced. If your machine uses a solenoid valve to control weather the pump is washing or draining. The drain valve may be stuck somewhat open, diverting wash water down the drain. Or the wash valve may be not opening fully. Different machines work in different ways.
Nov 09, 2013 | Dishwashers
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Spots are left on the dishes after washing. Dishes don't look clean
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Nov 26, 2010 | Kenmore Washing Machines
After the last wash I noticed the bottom of my dishwasher (Whirlpool quiet partner 2) was filled with water. After unloading the dishes I closed the dishwasher and pushed the Cancel/Drain button but the...
1.Check the drain filter for clogging.
2. Check the drain hose. Remove carefully to avoid water spill.
3. Check whether flows freely from the hose.
4. Check the drain valve if possible for you.
Sep 15, 2010 | Dishwashers
Dishwasher leaves film on the dishes
If your dishwasher is a few years old and just started leaving a film on your dishes there is a filter under the bottom adjitator that you have to replace it can't be cleaned jf
Jun 13, 2009 | KitchenAid KUDR24SE Built-in Dishwasher
FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Silverware and dishes not getting clean, leaving grit on dishes
It cleans poorly If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Mar 03, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dishes not clean
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
83 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
