Question about LG Washing Machines
Lg wm14311fd. how to remove the drum from plastic casing to change bearings
Im trying to change the bearings but cant get metal drum out of the plastic casing. spindle is stuck fast
MNTECH
  • 1543 Answers
SOURCE: bad bearings on front loading lg washer 1832cw
Sorry, but you are not so lucky. LG should not even offer those parts, as it takes special hydraulic presses to install some of that. For anyone but the manufacturer them self you must replace the back half of the outer drum (I believe it is a 3045ER0008C in your case) which contains the installed seal and bearing, plus I'd recommend replacing the spider asm 4434ER0002A, as the shaft may be a bit worn where it contacted the seal and bearing, and you don't really want to go through all that work (at least 2 hours) only to have to do it again. A FixYa rating would be appreciated. Thanks.
Posted on Nov 13, 2008
SOURCE: Ball Bearing Replacement
when spinning , it is noisy. How to overcome it.
Posted on Nov 25, 2008
stradeteox
  • 88 Answers
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Posted on Jan 08, 2009
AndreaBl
  • 218 Answers
SOURCE: Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Posted on Jun 11, 2010
  • 170 Answers
SOURCE: The drum inside my ge wbvh6240fww washer is loose.
There is one bearing in rear tub/bearing is part of rear tub...To repair that unit you will need a rear tub/inner basket with spindal and possible a front tub if it damaged..If i was you I would price the parts b/c you may not want to repair it as it can be costly .....Good luck
Posted on Feb 01, 2011
How do I stop my GE dryer from squeaking
Check belt look for location of noise and look for items in that area you should locate with process of elimination .
Mar 03, 2016 | GE Dryers
My ge clothes dryer started making a loud skreaching noise im positive its the drum rubbing on metal in the front of the dryer how do i replace what ever is in between that seperates the 2
You need to replace either the front bearing (plastic that drum rolls over) or the glides that go on the front bearing ( glides that insert into the plastic bearing piece that the drum glides on.I would change both, simply remove the top of the dryer then you will see two 5/16' bolts that hold the front to the sides just inside on the top, remove the two bolts and remove the front of the dryer and you will see the bearing and glides that I have described. Replace,reassemble and begin quiet drying again. Good luck!
Aug 08, 2015 | GE Dryers
Help! changing drum bearing lg wm2277hw
The best way I can suggest through my own personal experience is to turn the tub upside down withthe spider shaft facing down. Hold the tub up in the air about a foot and drop the whole tub on to the ground letting the shaft hit the pavement. It may take a few times to do it but it has always worked forme.
Hope this helps.
Nov 05, 2011 | LG WM2277H Front Load Washer
I am replacing the bearings on a WF860 machine. I have the plastic drum off and split but cannot drive the shaft out of the end bearing in the plastic drum. I have tried hammering the end supporting the...
ok..i will give you a couple of solutions go slow ,,becaues i understand your trying to save your spin tube,,did you try and soak it with wd 40....now what i do is set the plastic outter tub on a solid edge
and let the inner metal basket dangle..and whit a nice 2 pound hammer and i use a nut drive pund down evenly ..its hard no quetion in some case because the metal shaft swell up,,,most inner spin tubes are stainless steel so they have a lifetime warranty...if you can get a helper you can try unscrewing the parts the helper turns one way and you another...good luck
Sep 07, 2011 | Hotpoint Ultima WF860 Front Load Washer
Our whirlpool gas dyer is squeaking what could be the problem
Three things: the front and rear drum bearings and the drive belt+ it's idler pulley. The drum's front bearing (s) is/are the usual source of squeak. Some front bearings are just flat plastic surfaces mounted to the opening in the front panel, other types use a series of rollers that support the drum front. In the plastic strip types, if not worn through to metal, merely require cleaning of the plastic strips and the mating drum surface. The roller types usually have an internal bearing problem and should be replaced if light oiling doesn't help. In both cases, the top must be removed, then the front pulled back enough to service the bearing (s). Hope this helps!
Jan 26, 2010 | Dryers
I'M TRYING TO REPLACE THE DRUM BEARING ON AN LG WASHING MACHINE
Try this website, they have parts, and a tab you can click on to see your dryer in parts.
Good Luck,
I hope this helps.
http://www.repairclinic.com/LG-Dryer-Parts
Nov 12, 2009 | LG Dryers
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
May 30, 2008 | Washing Machines
Suspect drum bearings
LG Direct Drive bearing replacement The following guide is written to help you assess if replacing the bearings is a job you can undertake and complete. This is not written to be specific to any particular direct drive model but it will help in all cases.
Must do's Before commencing work on an electrical appliance:
1) Unplug the appliance from the wall socket, ensure the appliance on/off switch is in the off position.
2) Turn off the inlet water at the isolation valves and disconnect the inlet hoses from the appliance.
3) Clear a space and plan where you are going to put items you remove from the appliance.
4) Have pen and paper handy for making notes, a digital camera is ideal for taking a picture of wiring connections for future reference (**PHOTO**)
Strip down 1) Remove the worktop by undoing 2 screws at the rear, slide backwards and lift off.
2) FROM THE BACK.....Remove the back panel (4 screws) giving access to the rear of the tub unit. Disconnect the wiring to the motor, thermostat and heater, disconnect earth wires, (**PHOTO**). The drum pulley, which is the ROTOR of the direct drive system has a single bolt to undo. Slacken this bolt a turn or two, DO not remove completely. Gently tap the bolt with a soft faced hammer or drift, this will assist in the removal of the Rotor. Remove the bolt and remove the rotor, careful as it has a series of magnets around its inner circumference. The stator of the direct drive system is now in front of you, there are 6 bolts holding it in place. Remove these and very carefully remove the stator without damaging it, its very expensive, look after it. Depending on your model there could be a spacer between the stator and the tub unit, if so remove this also.
3) FROM THE FRONT.....Open the filter door (left side of kick plate) if there is a small drain hose, remove stopper and drain off any water in there. There is 1 screw to remove which is at the side of the filter, then slide the kick plate sideways should release the plinth from the cabinet. Open the door, the seal clamp band that secures the door gasket to the cabinet should be removed. If the door seal has a further hose attached, remove it.
4) Read all of this paragraph, there are 2 versions.....Remove 3 screws holding the lower edge of the front panel to the cabinet. Remove the soap drawer, remove 2 screws in the control panel that secure the soap box, depending on model there could be a third in the lower right hand corner, if there is, remove it. If there isn't read on further.. Carefully slide the front panel downwards about 20mm and it will disengage from the cabinet, carefully look behind it and disconnect the door lock wiring to allow complete removal. If there was not a third screw (lower right hand corner of the control panel) then the control panel will have to be removed. From the top remove the clip retaining the hose that goes into the top of the tub unit, remove the clip holding the large hose on the left, slide the soap box backwards slightly and hang over the back of the cabinet, all the hoses still connected. To remove the control panel look under the top frame and release the two lugs whilst easing the panel away from the cabinet. disconnect the wiring and remove away completely.
5) From the bottom remove the sump hose from the tub, the screw that secures the pressure bottle to the tub. Remove the suspension pins from the top position of the legs and push the legs clear of the tub unit. The tub unit will now be hanging from the top springs. Using strong wire or rope, loop the hook of the spring, lift clear of the cabinet and lower the tub unit to the floor. Repeat this on the other spring which then allows the tub unit to be lifted through the front of the cabinet.
6) Place the tub unit door seal up, remove the screws that secure tub front 1/2 to the rear 1/2. This allows the inner drum to be removed, if its tight use soft faced hammer, DO NOT damage the drum shaft.
Inspect the drum shaft collar, the collar is located at the base of the shaft and is the surface that the oil seal mates to. Look for indents or circular ruts where the previous seal has worn the collar away
6a70_2.jpg if damaged you will need a new spider unit. Do not clean up using abrasive cloth, try the green pan scrubber from the kitchen instead. If damaged and you don't replace it the bearing replacement will fail prematurely as the oil seal fails to keep the wash water away.
There are several different kits, comprising of 2 bearings and 1 oil seal. To obtain the correct kit you will need the model number of your appliance, eg WM1480FHD or WM1485FHD or WM16225FD
all use bearing kit 1 available here other kits are available for other models including belt drives and washer dryers
The bearings can now be removed, the seats cleaned and made ready for the new bearings and water seal. A light cover of grease can be smeared on the inner edge of the seal.
7) There is a tub seal which fits in the recess between the front and rear 1/2's of the tub unit, it is adviseable to renew that seal before rebuild is commenced.
8) Rebuild is a reversal of the above, at every step double check electrical and hose connections and before you refit the cabinet front.
Hope you find this guide useful, some paragraphs can be applied to the belt drives also.
Nov 18, 2007 | LG WM-1485FHD Front Load Washer
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
