Removing timer knob from whirlpool washer GST9679PW1
  • 34 Answers
If you look at the back of the timer lined up with the center of the Knob there is a black or gray plastic part pull that out about an inch then the kbob will come off
Posted on Jan 03, 2009
I have to replace the timer knob on my whirlpool LTE5243DQ3 combination washer and dryer,but I cannot remove the old one
oh boy these are varied in the way to remove them, but usually under the knob is a pin, or screw and in some cases a u shaped plastic pc that locks timer to knob shaft? in some cases on the back side the shaft has to be pulled up then remove the locking pin or u shape piece to release it and wow it comes off
Aug 19, 2014 | Whirlpool 27 " White Combination Washer...
How do you replace the timer in a Kenmore Washer Model 22622?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=41610396bdeaf9d724c8d6b9910df259
Basic Whirlpool / Kenmore washers may use one of two different timers. See the following Whirlpool / Kenmore Service Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that you have the metal timer, You'll need to remove the timer knob. The easiest way is to hold the metal shaft that passes through the timer with a thin needle nosed pliers while un-screwing the knob.
Once the knob is off, it's a simple matter to unplug the connectors and remove the bolts holding the timer to the console.
Oct 21, 2010 | Kenmore 22622 Top Load Washer
I have a Kenmore washer model 110-20712991. the timer doesn't advance. Wherever I put it, it stays there and only does that functions, never advancing to the next position. Is there any test i can perform...
It does sound like a bad timer:
See the following: This is a Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has testing instructions as well as directions for removing each of the two types of timers.
If your timer is the one with a knob that un-screws, use a thin needle nosed pliers to hold the shaft going thru the timer while you un-screw the knob.
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Jun 08, 2010 | Kenmore 24032\24036 Top Load Washer
How do you remove the timer on a Whirlpool washer
You have to unscrew the knob and remove the screws that are under it, some have just a center nut with a locating tab that goes into a hole to hold it straight.
Oct 24, 2009 | Whirlpool Washing Machines
Whirlpoole gold top loader stop working
Try pushing down on lid switch. common problem for these models.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Removal of cycle time knob waching machine whirlpool lsr5233a
push knob in ,with the front panel unscrewed lift up to back side of the knob,there is a black plastic pin in the center of the knob.pull the pin out and it releases your knob
Dec 01, 2008 | Whirlpool 3362624 Washer Control Timer...
Whirlpool ultimate care ll washer
on the back of the timer is a black plastic tab, you have to pull out on this tab in order to remove the knob. in other words you have to take apart the control panel to get to the timer just to take off the knob. :I
Jun 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
