Question about Acer Aspire 3680 Laptop
All i get is a curser
When my acer powers up I hear a clicking sound then all i get is a curser on my screen and then it stops moveing from there
  • vernando008 May 11, 2010
    Hi,what is on your screen as well as the curser ie. black screen or bsod or windows logo etc.
I have a new laptop brand is acer programmed by Windows 8 I can not unlock the screen curser when trying to inser password but the curser also will not move to type the password and is frozen
Hi Charlotte, i hope i understood properly, but it appears that you have a possible issue with the keyboard & or the touchpad. As this is a new unit then the only advice to give is to contact Acer tech support (unit is under warranty) who should be able to guide you through the issue.
Feb 02, 2014 | Computers & Internet
Curser freezes when user name clicked on
We can help you for free http://www.geekshelpme.com/support/remote/
Mar 16, 2013 | Acer Computers & Internet
My mouse curser moves to the middle of the screen and clicks by its self
It sounds like there is a problem with the touchscreen. Seems to have a bad spot and thinks it is being touched. In device manager of the control panel, you should be able to disable it under human user device. Double click on that to make sure that is it and select "do not use this device" or "disable" to see if that is the problem. Also, the drivers of the wireless kb and mouse may not be compatible with win8 and interfering with the touch screen.
Mar 15, 2013 | Acer Aspire Z5700 PC Desktop
My HPw 1907v flat screen makes a poping noise after waking it up and when moving the curser up and down the page the screen wobles when it moves over the subject headings.
hmm.. do you mean the buzz sound? if that, it are casing bad Grounding... or battery problem.... u shuld hear strange sounds then inserint USB drives...
Jul 09, 2012 | HP Computers & Internet
Curser doesn't move... on my Logitech Trackman Wheel - 3-btn Trackball - Wired For some reason my curser used to just drop to the bottom left of the screen during operation which was quite frustrating... I...
Sounds to be a hardware problem. especially if it would move by itself at times, now not at all.
Windows is detecting it correctly, right?
If so, then i would say time for a new one.
Aug 17, 2017 | Logitech Trackman Wheel 904353-0403...
Intermittantly the curser freezes then erratically moves around the screen by itself. I am unable to move or 'control' the curser so find it difficult to shut down to do a re-start. I usually have to hold...
Make sure that you are not placing the hand on the touchpad while typing.... This might be due to the drivers issue with the touchpad.. Try to unistall the drivers of touchpad from the device manager.. Then install a fresh copy from the dell website(www.support.acer.com).. If the issue is yet to be fixed please contact Acer to replace the touchpad....
Sep 16, 2010 | Acer Computers & Internet
Wireless mouse curser does not move new batteries installed
If the mouse totally stop working like left/right click, moving, etc then i suggest replace the battery of your mouse and try. If the same result then again install the driver & restart the netbook.
Thanks waiting for your feedback.
Jan 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire curser pad not opening programs
Regarding the touchpad (curser pad), there maybe a problem with your touch pad driver not working or starting up. Check in "msconfig" (you can click on start and run, then type msconfig to bring it up) and click on the startup tab to check which of the startup items are not working.
Also regarding the card reader, i believe the drivers are not installed. Check in Device Manager (click on start /control panel /system icon /device manager) and see what is listed under "other devices"
Mar 06, 2009 | Acer LXA3706003 Notebook
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3680 Laptop Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
