Question about Refrigerators
Beko glacier fridge/freezer cg964 keeps freezing in the fridge part. Defrosted 2 days ago & already freezing. Fridge on lowest setting & thermostat says its at correct temp.
2 Suggested Answers
Todd_pdx
  • 22 Answers
SOURCE: Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Posted on Apr 06, 2009
Why is fridge freezing the food?
If your refrigerator has a separate "cold control" it could be defective.
Jul 19, 2014 | Beko Fridge/freezer Thermostat Genuine...
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
My beko glacier freezer is not freezing
evap coils could be frozen due to bad defrost timer or heater. could be a bad evap motor or worst case the compressor could be bad
Feb 10, 2012 | Refrigerators
Fridge/freezer not working
check the condensor fan if that aint it unit may be low on charge
Apr 24, 2010 | Freezers
Apr 06, 2009 | Refrigerators
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
FREEZER KEEPS ICING UP
lol.. welcome to my world... I have my fridge set at the lowest without turning it off...IT FREEZES a gallon of tea in 5 days!! My freezer ices some.. its set at 3..(1-6).. BUT I like keeping frozen foods FROZEN.. I deal with the ice...
I have asked several repairmen.. they just guess...I am NOT going to spend money for something that is a GREAT Frig/Freezer.. better than TOO HOT and ruining food!!
Sep 24, 2017 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
