Question about Brother Multi-Function Center MFC-8870DW All-In-One Laser Printer
Wireless failure Trying to set up new 8870DW using wireless. I have Vista and XP laptops which network properly with each other when wired but do not see each other at all using wireless. Wirelessly they both reach the internet normally. They both can see my Meraki antenna repeater device which is wired into my router. The 8870DW control panel can see the meraki device. Neither computer can see the 8870. The Pro suite is installed and the 8870 is listed but it does not print or indicate that a job was pending. I would think I should be able to print regardless of the Vista/XP problem. Is the 8870 problem related to my Vista/XP wireless network problem? Is there any way for the machine to print it's internal settings such as IP address etc. Any suggestions will be appreciated.
    Novelist:
  • 163 Answers
Did you tryed it to reconfigured the device?
Posted on Jan 02, 2009
    Brigadier General:
  • 5,158 Answers
If the computers cannot connect by wireless to the net work it is unlikely they will connect to the printer. right click on the network icon in the systray (lower right hand side of the window) and select diagnose and repair from the list on each computer... it will either fix the network or hopefully tell you what is wrong
    Genius:
  • 3,422 Answers
HI,
Please click on the below link.Its a network guide for your model.Go through it.It will tell you how to configure your router,MFC,xp and vista so that you can use it wireless.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002060/MFC-8870DW_UsaEngNet.pdf
Trying to load software, i get to the second stage it tells me the ethernet cable is not connected properly. i cant get past this.
It seems that you are using usb connection to install your router. This error happens, to some, due to incompatibility issues. I suggest for you to set your wireless network by way of general steps and common cable connections. Let's put it, the old ways. This are the general steps for all types of routers.
Click the link below for proper cable connections in setting up your wireless network.
This link also provides somewhat a checklist on what you need for wireless connectivity
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Then, configure your wireless connection. The following links provides the step by step instructions for each version of Windows:
Windows XP. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Windows Vista. http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Windows 7. http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 01, 2011 | D-Link DIR-615 Wireless Router
How to connect Linksys WRT150N to laptop on DSL
I hope this works for you. Good Luck!
Thanks.
Mongkey
Jan 18, 2011 | Linksys Wireless-N WRT150N Router
How to add a printer in Vista
your best bet is to install network magic to control your wireless network. http://www.purenetworks.com/product/basic.php the essentials is the best option for you. it may cost $29.99 . from this site u can easily do this
Oct 02, 2009 | Office Equipment & Supplies
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Problem with downloading router driver/firmware
You don't need software for the router. Is your wireless encrypted or open? Just view avaiable networks with your xp machine and choose your network to connect to. If you do have an encrypted signal use the vista machine and type in the ip address to the router in your browser window. I think belkins router ip is 192.168.2.1 or 192.168.0.1 Hope this helps, let me know
May 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Unable to connect my wifi laptop to my existing wireless b/band
Your wife's laptop is setup to connect to another wireless network. It must be set up now for the wireless network that you are trying to connect to. This means that your wife's laptop is trying to connect to the wireless network somewhere else. You need to let the laptop look for available wireless networks. It should be able to see your wireless network. It will then require you to enter the password that you have set in your Zyxel. If you don't know the password, call Zyxel.
Feb 23, 2009 | Zyxel Prestige P-330W Wireless Router...
Fifth computer unable to connect to internet
-- ckeck if you see 'wireless connection' in the network connections, in order to find it, click start --> control panel --> network connections and you must see wireless connection in case of win xp..
start --> control panel --> network and internet --> network and sharing center --> manage network connections and you must wireless network connection under LAN or hi speed connection... in case of win vista
--if you have that ikon that means you have your drivers installed on the computer properly
--right click wireless network connection and click "view available connections" in case of  xp and "connect/disconnect" in case of vista you must find the network and get connected..
letme know if you have problems connecting..
Jan 24, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Dg 834g router
is this a wireless network?
are you trying to retrieve SECURITY codes, or just basic network settings?
your best bet is probably to log into the router, from the vista laptop, rather than looking at the settings the vista laptop is currently using...
on the vista laptop, open a webbrowser, and type in the ip address for your router.
that is PROBABLY 192.168.0.1
the username is PROBABLY admin
the password is PROBABLY "password"
from there, if you click on wireless settings, it should show you all the details you need.
did the people who set this network up for you leave any information about username, password, ip addresses, anything like that?
Mar 26, 2008 | Computers & Internet
XP and Vista wireless LAN - computers don't see eachother
Here is an article that should help -- there may be a issue. based on this article the Vista Computer is connected to the internet or ISP's network with a wire.
Ad-hoc networking access point
Dec 17, 2007 | Computers & Internet
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
Brother Multi-Function Center  MFC-8870DW All-In-One Laser Printer Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
