Question about Hitachi 51G500 51" Rear Projection HDTV-Ready Television
51' projection tv(Hitachi 51G500A)
We have a cracked outer screen on this tv, it looks like plexy-glass. Is it possible to repair it myself, I checked with some repair shops and it would cost around $600.-$800., not sure I want to spend that much. This tv is under three years old. Please advise, thank you.
    Problem Solver:
  • 7 Answers
So it says. 1080p actually according to the manufacturer. I am getting one tonight myself so, I hope so...
Posted on Jul 29, 2012
I have a stupid question. Is a Hitachi 51G500A HDTV?
Posted on Dec 16, 2007
  • 398 Answers
The Hitachi part number for the screen assembly for the 51G500a is KR02844. You can call a Hitachi parts distributor and see for yourself how much those things cost, but I warn you they are not cheap!
Posted on Jun 26, 2007
SOURCE:
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Where is the lamp located on my HITACHI 51G500A?
51G500a is a rear projection CRT type set----It has no Lamp--it uses three picture tubes.
What is the problem with the set? Verify model number posted here is or is not correct.
SD TECH
Aug 16, 2010 | Hitachi 51G500 51" Rear Projection...
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
I am looking for a new outer screen for my samsung hcp4752w TV as it was cracked, it is a kind of smoked plexi-glass can anyone help?
I can sell you a used one in good condition from my broken set, let me know if you're interested. Give me your e-mail address and I can e-mail you with details.
Dec 02, 2009 | Samsung HC-P4752W 47" Rear Projection...
Hitachi 51G500A and the screen when blank
Hi I am vortash I have just looked at the service manual for this set and it actually does not use a bulb as it is not an Lcd or DLP projection TV . It actually employs three CRT based tubes that produce the picture with automatic focus and convergence systems . If you do not have the manual for this set you can download it from http://www.safemanuals.com free of charge It says that if you have sound and no picture turn the set off and unplug it for 3o seconds then replace plug and turn on from switch on set not from the wall plug switch .. as this may reset the tv and cure the problem .. hope this helps regrads Vortash
Jun 08, 2009 | Hitachi 51F500 51" Rear Projection...
I have a 51in Toshiba that nees a protective screen.
The plexi glass if a "special formulation" and costs around $350 if available!. I would go to some repair shops and see if they have old junker sets (city dump) that you can get the screen and if you have to cut it to size.. Cheap fix...
please rate!
Mar 11, 2009 | Hitachi 51SWX20B 51" Rear Projection...
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
438 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
