Can some one tell me how to fix this problem i'm having
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL UP. If the device responds, no further programming is required.
Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction to forward again.
5. Press and release MUTE to install the code.
i cant seem to get my philips remote to program. anyone have any advice?
I was able to do this and got the remote to change one channel. I pressed and released the mute button but then nothing happened. I still can't change the channels or turn the tv on/off with the remote.
