Question about Viking Dishwashers
Viking VDB450SS Dishwasher Diagrams - Viking Dishwashers
4 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Viking VDB450SS i have the same
Please check the door switch in the first place , remove power to the washer and check the continuity of the switch , Now trace the wires to the main panel controller check on the connections on the main panels, check all the wires leading from the main panel to the valves, pump and the motor.
Once you have made sure that the connections are correct, then check the cycle/program as the washer is switched on.
The blinking is an error and is related to a processor resetting due to its failure or an input problem.
There are no controls active on the customer pad and so no reset is possible.
Remove the power and remove the controller unit , warm up the unit to clear off any moisture. Disconnect one by one the outputs , the valve, the pump, heater and the motor.
If the blinking is relative to a short then the related removal of wire to the circuit will bring back the controller to reset.
If none of these works the possible fault can be the controller unit.
Posted on Feb 17, 2011
BElectric
  • 1140 Answers
SOURCE: dishwasher viking model vdb450ss error
Hello there,
If you're certain this model number is correct, the error code indicates a "drain timeout error". This means the machine has tried and failed to pump out within a specified time limit. Please run through the following checklist to correct this problem:
1. Check and clean the filters
2. Check the drain hose isn't kinked and check for any blockages in the drain hose.
3. Make sure the hose has a high loop as per the installation instructions
4. If draining into a garbage disposal . . .
- Remove the plug from the disposal to allow air entry / eliminate any potential vacuum.
- Run water through the disposal to check for blockages
5. Ensure dishwasher is level, front to back and left to right.
When you've checked all of the above, reset the dishwasher by holding the START button for a minimum of four seconds to clear the error message.
My slight question mark over the model number is because you referred to "heavy cycle". The VDB450SS does have a heavy cycle but it's called "pot & pans" on this model. Other Viking dishwashers explicity say "Heavy" but a flashing LED above heavy on another model may indicate an entirely different fault. This is an overfill error code on some models.
If you definitely have the VDB450SS, you should be able to solve the problem using the checklist above. If you have any other model. please reply to me by clicking on "Add a Comment" below your question for further assistance. Please verify the correct model number if/when replying and whether any other LEDs are also flashing.
Thanks,
BElectric
Posted on Mar 04, 2011
KevinWhite
  • 1902 Answers
SOURCE: Viking Dishwasher VDB450SS Unit appears
Hello & Welcome to FixYa
Check the door latch switch mechanism as that seems to be bad and needs replacement as everything else is working fine. Please get back to me if you have any other questions.
Kevin
Posted on Jun 18, 2011
Viking dishwasher parts
Yes, please type in " viking dishwasher parts diagram" into your computer, and you will see whatever you need!
Be blessed.
Feb 23, 2013 | Viking 24 in. Professional Series VUD141...
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
My Viking Professional VUD 141 DISHWASHER will not pump water through the spray arms
I have a viking VUD140 and there is no power cord. Can someone tell me where the power supply is suppose to go.
Dec 30, 2009 | Viking 24 in. Professional Series VUD141...
30 yr old Viking dishwasher leaks...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
tyue56
Aug 06, 2009 | Viking DFUD04 Built-in Dishwasher
Detergent dispenser
Here is a link. Sears.com as almost any part for anything including diagrams. The pricing on the part seems WAY out of range. Usually dispensers cost around $60.00 At least you can find the p/n and google around for it on some other sites. I can't imagine it's that much.
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=PD150001&productGroupId=0022&supplierId=425&brandId=x&documentId=10057058&keySuffixId=NA&modelNumber=x&keyId=000018&pageId=00002&productTypeId=x&searchModelNumber=VUD141&subCompDesc=Door&brandDesc=VIKING%20RANGE%20CORP.&modelDesc=UNDERCOUNTER-DISHWASHER&backToLink=Return%20to%20part%20list
Feb 15, 2009 | Viking 24 in. Professional Series VUD141...
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Viking dishwasher leaking!
Leaking Dishwasher
heatman101
ty
Dec 28, 2008 | Viking 24 in. Professional Series VUD040...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
VIKING DISHWAsher doesn't work U040SS
your dishwasher is leaking into a tray underneath tripping a flood switch find the leak fix the problem
Jan 20, 2008 | Viking 24 in. Professional Series VUD040...
Viking vud141 - timer does not end the cycle
you can try this number 305-418-0010 they have everythin for viking product and very cheap
Dec 09, 2007 | Viking 24 in. Professional Series VUD141...
Dishwashers Logo
79 people viewed this question
Top Viking Dishwashers Experts
Mike
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
