Question about Canon ImageRunner 3025 Black and White Copier
Canon ir3025 print head - Canon ImageRunner 3025 Black and White Copier
3 Suggested Answers
redzventures
  • 149 Answers
SOURCE: How do I cancel a print job on a Canon iR3025
Press the 'MONITOR' tab at the bottom of the screen and then select 'PRINT' and then the job and select cancel.
Posted on Jul 09, 2009
canontech
  • 1219 Answers
SOURCE: iR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
Posted on Jun 16, 2010
Print outs are coming blank in ir3025 ????
This might seem basic, but sometimes we overlook it when changing ink, or drums. Most come with a plastic seal at the bottom that you need to remove. Check if is still attached. Also, some laser printers need that a bar is slided to the opposite side (sometime back and forth) before installing the new cartridge.
After changing, try realigning, or notifying the system you changed the drum or the cartrigde; sometimes the problem is that is software locked. Hope this general guidelines help you.
Dec 22, 2014 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
Canon ir3025 printing problem only printing landscape
Great answer thank you - you just need to move the blue dial!!! :-)
Apr 01, 2014 | Office Equipment & Supplies
I get lines on paper when printing on canon ir3025
I had somewhat the same issue with my Canon i9900. In fact it took THREE tries before I got it working correctly. On the first printer the ink carrier would never move. Canon sent a new printer right away. It worked about a week, then everything went red. I called and also talked with the service rep. Like you, they insisted I load the goofy Easy Print software instead of printing from Photoshop. Trouble is, Easy Print only works with Jpegs. Well, anyway, I did it, and of course it made no difference. So the rep felt it was a bad print head, (which is replaceable on the i9900. They sent me out TWO new heads, I replaced it, and it did fix the problem. I have used the printer for a few years now, but just once in a while I will get some lines, or more like smudges. A cleaning cycle usually takes care of it. I still have another new head if it ever gets too bad. I don't know if the print head is replaceable on your model or not, but it might be a place to start. Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 12, 2014 | Canon ImageRunner 3025 | IR3025 |
Toner smudge
Try taking out the toner drum to clean it thoroughly.It sometime happens becauses of the extra tonner spilled over the head.
Oct 01, 2013 | Canon ImageRunner 3025 | IR3025 |
E000100-0001
press*#additional functions#. machine will display the following screen
service mode level 1 . from their choose copier. Go to adjust - clear- jam history-ok. Then err history - ok. Turn the machine off and on again. Your machine should wor fine.
Jan 31, 2013 | Canon IR3025 COPIER FOR 220 VOLTS ONLY
Canon ir3025 error code e000024-0001
E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just needs a clean or replacing or the the cable ties to the toner sensor are to tight near the dev assembly just cut them off.
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR3025
SOLVED Canon IR and IRC Printer Errors E000024 and E000025
See also page 2-107 (figure 640) here:
http://www.arbikas.com/view/locator/ir3045_3035_3025-pc.pdf
Nov 26, 2012 | Canon ImageRunner 3025 | IR3025 |
Download Canon ir3025 manual for free
Manuals for the Canon imageRunner 3025 can be downloaded in PDF from the Canon website.
Drivers and software can also be found on the same site by clicking Drivers & Software.
Feb 02, 2012 | Canon Office Equipment & Supplies
IR3025 can not print, Status NG
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
May 06, 2010 | Canon ImageRunner 3025 Black and White...
Jul 08, 2009 | Canon ImageRunner 3025 Black and White...
Canon ImageRunner 3025 Black and White Copier Logo
21 people viewed this question
old marine
old marine
