Canon ir-2870 prices in raipur - Office Equipment & Supplies
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Posted on Mar 16, 2008
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
0jasgaur
SOURCE: Error E000024-0001 on Canon iR 2870 Photocopier
WHEN MAKING A FIRST COPY OF ANY DOCUMENT THE FOLLOWING ERROR APPEARS e000024-0001
Posted on Sep 06, 2012
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
2870 canon copier machine showing error code E000024-0001
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon 2870 copier showing error E000024-0001
open your developer unit and check sensor , refix it an close unit see........your problm solved
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
IR 2870
Sep 09, 2008 | Canon imageRUNNER C3200 Copier
20 people viewed this question
k24674
