Question about Microsoft Xbox 360 Console
Power cable light is orange and xbox 360 wont turn on
The power cable light is orange for my sons xbox 360 and the console wont turn on and the light is supposed to be green i have tried another power cable but the same happens
    Problem Solver:
  • 5 Answers
Try checking the usb is it damaged? the pins in the usb may be shorted to ground..pry any pins up and the system will work..this happened to me.
Posted on Mar 02, 2009
USB pins are shorted to ground came to this site yesterday and fixed it this morning.If you have a volt/ohm meter check ohm readings between the metal frame and the pins of the usb out of four pins ONE should be a low ohm reading the other three should be infinity.The one that should be low ohm is on an end.
Hmm sounds similar to me. I saw a post stating that usb port where the controllers are connected were shorting out to ground. So I took my 360 apart and sure enough the pins were shorted to ground. A good thing to check is the orange light on the power brick. If before you plug it into the back of the 360 its a steady orange light and then you plug it into the console it blinks (pay attention) its a good possibitility that it is shorting out somewhere in the console. If you have a mulitmeter you can check the back of the power plug input to ground or the controller usb to ground. Even though I found that this was my problem with my xbox unfortunately for me my board was also fried. From now on Im going to collect xbox's that are broken and use them to fix my new xbox when it breaks(im sure it will) because microsoft enjoys putting out an infererior piece of ****. I'll be dam*** if ill pay anyone a penny and wait half a year to get a repaired (but still broken) xbox back, when I know Ill be able to fix my own. Maybe Ill open up my own 360 repair shop just to show microsoft how. customer service should be handled. Anyway hope that helps and you have better luck then I did.
Posted on Mar 28, 2009
No the light is supposed to be orange because mine is and it works just fine but maybe your not pushing the cable in hard enough
Posted on Jan 02, 2009
My xbox power box is displaying the amber light and the xbox wont switch on is this related??
An orange light is illuminated on the power supply for one of two reasons. Either the console is turned off or the power supply is disconnected from the console. The orange light means that the power supply is in standby.
Even if the console is turned off, the power supply light may still be illuminated orange. This can occur if the power supply cord is not fully inserted into the power socket of the console.
Click Here For Toubleshooting
My YouTube
Click Here For Live Tech Support
Apr 18, 2013 | Microsoft Xbox 360 Console
Power supply light stays orange and wont turn on the XBOX PRO. HELP!
I hope this helps The power supply light is orange for one of the following reasons:
  • The console is turned off.
  • The power supply is not plugged into the console or the connection is not tight.
  • The power supply is not functioning properly.
Note An orange light usually indicates that the power supply is connected to electricity and ready to power the console. When you turn on the console, the power supply light should change from orange to green. If your console does not turn on, please see the following Knowledge Base articles: 907588 (http://support.microsoft.com/kb/907588/ ) Your original xbox 360 console will not turn on
2122656 (http://support.microsoft.com/kb/2122656/ ) Your xbox 360 S console will not turn onIf the console will not power on and you have tried the troubleshooting steps in the above article, your power supply will need to be replaced.
Contact xbox Support to obtain a replacement power supply. For information about how to contact xbox Support, visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Jan 04, 2011 | Microsoft Xbox 360 Pro System Console
My sons xbox 360 wont turn on
Check the power supply unit, if the light is green or orange and still doesn't power on, try pressing the eject button on the xbox it should turn on if you do, if the power supply is red then you should contact xbox support.
Oct 21, 2010 | Microsoft Xbox 360 Console
My powerbrick lightis orange but my xbox360 wont turn on
If the light on the power brick stays orange after turning the console on it means the brick is not properly functioning. You can attempt to clean the power brick with a can of air. Also make sure it has ventilation and is not sitting on carpet. This can cause the power brick itself to overheat and cause issues with it and the console itself. Also make sure your 360 is not plugger into a surge suppressor as this can cause issue due to double protection.
If possible, test the power brick on a different console, and test the console on a different power brick. This will narrow down your problem area.
Dec 22, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 wont turn on can some one help
The A/V cables are not pushed in all the way
Jul 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 won't turn on!!!
When it says ORANGE on the Power box, that means that the Power box is waiting for the console to be connected, You might wanna try another power box if you have a friend or relative nearby, and if another power box does the same thing, then you can call xbox support to check the warranty of your xbox 360, then send it in for repairs
FYI:
The light on the power supply should be GREEN in order for the console to turn on
Mar 15, 2009 | Microsoft Xbox Console
Xbox360
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one
Sep 06, 2008 | Microsoft Xbox 360 Console
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
861 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
