Question about Motorola Mobility ES400S
Es400 typing slowly
When using certain applications my es400 is very slow to display the typed characters on the screen, any ideas on how to speed it up?? I have performed several O/S Reboots (1,9 & Power) to no avail..
Facebook cannot log in..why?
You might have forgotten your password, or you might have CAPS-LOCK on or been holding a shift key while typing out a character. Check these and try keying in your password slowly and pay attention to each character as you type them out. This should certainly work.
Oct 13, 2012 | facebook.com
IBM 1500 by Lexmark
If it is moving as the hammer is struck, then it's one of two things. Either the hammer is moving too slowly, or the ribbon is moving too quickly. Since this is a rather old machine, it seems more likely things would slow down than speed up. I'd check the hammer solenoid. See if it's dirty, or needs lubricated. I wish I could give you more advice on this, but I am not familiar with this specific model, and was unable to find any kind of service manual, or troubleshooting information for it.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
Tip
How To Reset Your Blackberry Smartphone
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press and hold the <b>Alt</b> key. </li> <li>While holding down the <b>Alt </b>key, press and hold the <b>Right Shift</b> key. </li> <li>With both of those buttons still pressed, press the <b>Backspace/Delete</b> key.</li> <li>The display turns off to indicate that the reset has started, and the keys can now be released. </li></ol><span style="font-weight: bold;">Hard Reset</span><br /> <ol> <li>Remove the battery cover. </li> <li>Remove the battery, and then reinsert it after a few seconds. </li> <li>Replace the battery cover.</li></ol><span style="font-weight: bold;">Factory Reset</span><br />The following will delete all data and applications on the BlackBerry smartphone. Back up the data on the BlackBerry smartphone before proceeding. The process for deleting all data and applications can take up to an hour to complete. Do not remove the battery while data is being deleted.<br /><br /> <br /> <b>Note:</b> To identify the version of BlackBerry Device Software on your BlackBerry smartphone, go to <b>Options</b> &gt; <b>About</b><br /><br /> <p style="font-weight: bold;">BlackBerry Device Software 2.6<br /> Note:</b> If a password is already set, go to step 5.<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>In the Password field, press the <b>Space</b> key to enable the password. A dialog box will prompt for a password with at least four characters. </li> <li>Type a password. Click the trackwheel. Type your password again to verify it. </li> <li>On the Home screen, click the <b>Lock</b> icon. The Lock screen is displayed. </li> <li>Type your password incorrectly 10 times to trigger a security wipe. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 2.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.1 to 4.2.1<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Display the menu and select the <b>Wipe Handheld </b>option. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and then press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.2.2 to 4.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Press the <b>Menu</b> key, and select the <b>Wipe Handheld</b> option. </li> <li>Select the <b>Include third-party applications</b> check box to remove third-party applications. Clear the check box to preserve third-party applications. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 5.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe</b>. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 6.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe Data.</b> </li></ol><br /><span style="font-style: italic;">To reset a legacy BlackBerry device (</span><span>Research In Motion&reg; (RIM&reg;) 850, 857, 950, 957 devices)</span><span style="font-style: italic;">, insert the end of a paper clip into the small hole on the back of the device.</span><br />
on Feb 15, 2011 | Cell Phones
What causes keyboard to type characters very slow or not at all?
Sounds like your system may be updating or installing something thats taking up a lot of your Computers processor giving you a delay in your typing display.
Also this could be due to lack of system resources meaning you just have too much running for your computer to handle
Try cleaning up your Temp files using the clean up wizard and also on your taskbar next to your clock make sure there are not 20 icons as these are all programs running that can slow down your machine,
Watch the demo (1:00)
If you have download Windows Search, after install it will index your whole hard drive and network drives which can take days and slow down your machine as well
press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
you might have to many programs trying to or accessing your computer or the internet at the same time or a virus
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
hope this helps
Aug 28, 2012 | Dell Computers & Internet
I have recently purchased a new Acer Aspire laptop. Whenever I type a character on the keyboard multiple characters are displayed. The problem persists across all applications. I am sitting idle with the...
It sounds to me like you have a faulty keyboard. You need to contact Acer, or the store where the laptop was purchased, and arrange for the laptop to be repaired. This should be covered under warranty, unless the machine has suffered any physical damage, such as a fluid spill.
Jul 26, 2011 | Acer Aspire One PC Notebook
I have a flash application running on a Samsung galaxy tablet (Android 2.2 OS). The app requires that the user logs in. The app uses the tablet's native on-screen keyboard for entry of the username and...
This is a common problem with flash based inputs on touch screens. Things are a bit better on version 3.0 of Android. I hope that the galaxy tab is going to be dated to this version someday.
Cheers
Feb 28, 2011 | Samsung Computers & Internet
I have a customer with a Phaser 6360. The are
i think check your color space on the applications you printing from:)
Nov 24, 2009 | Xerox Phaserâ„¢ 6360/DT Printer
How to master reset a blackberry pearl 8220
To delete all data and applications from your BlackBerry smartphone, complete the appropriate set of steps below depending on the version of BlackBerry® Device Software you are running. Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data prior to wiping your BlackBerry smartphone. If content protection is turned on, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted. To identify your BlackBerry® Device Software version go to Options > About (For example, 2.6.x.x, 2.7.xx or 4.0.x.x) For BlackBerry smartphones running BlackBerry Device Software version 2.6 Note: If a password is already set go to step 5. On the Home screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. In the Password field, press the Space key to enable the password. A dialog box prompts you to type a password with at least four characters. Type a password. Click the trackwheel. Type your password again to verify it. On the Home screen, click the ?Lock? icon. The Lock screen is displayed. Enter your password incorrectly 10 times to trigger a security wipe. For BlackBerry smartphones running BlackBerry Device Software version 2.7 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld? For BlackBerry smartphones running BlackBerry Device Software version 4.0 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld?. For BlackBerry smartphones running BlackBerry Device Software 4.1 to 4.2.1 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Click Continue. Type blackberry, and then press the Enter key. For BlackBerry smartphones running BlackBerry Device Software 4.2.2 to 4.7 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Select the Include third-party applications check box if you wish to remove third-party applications. Clear the check box if you do not want third-party applications to be removed. Click Continue. Type blackberry, and then press the Enter key.
Oct 29, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Yahoo Mail has slow typing and response time . All other applications fine. Any ideas?
what brower are you using ? usually it is sometimes caused by script errors causing the browser to respond slowly. try clearing the temporary internet files closing the browser and restarting it again.
Aug 02, 2009 | Computers & Internet
Motorola Mobility ES400S Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
