Question about Kenmore Elite 45986 Front Load Washer
Getting F11 code r8ght after starting,then flashes and stops
My machine actually started making loud rackets while in the spinning cycle and has now displayed the F11 code after starting the washer. It won't even start a cycle?
    Scholar:
    New Friend:
  • 25 Answers
The F11 code is caused by either a CCU failure or an MCU failure...here's how to tell:
If your machine starts a cycle and the water fills but the drum NEVER turns, your MCU is bad...it's most cost effective to buy a refurbished one and you can get them on eBay for $99 all day long.
If your machine makes it most of the way through a cycle but throws an F11 code during the rinse or spin, your CCU has the relay solder / vibration problem...and I can fix that for $65.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181300988546
Posted on May 26, 2014
  • 530 Answers
Usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
Posted on Jan 04, 2009
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
The F11 error can be difficult to resolve even for us technician's.
The F11 error occurs when the central control and motor control don't talk to each other.
If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
When the washer goes into spin cycle, it makes a very loud noise and then the spin cycle stops and F11 appears on the screen
This just happened to me tonight too - but I ddint get the F11 code.
When I stopped the machine, there were small plastic threads everywhere and when I investigated - the white plastic ring that is covered by the gasket - if you pull the gasket back you can see it - was shredded! I am afraid of the cost to fix this one. My machine is about 7 years old. Is it fixable - or should I give up?
Jun 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When it gets to spin cycle, it starts flashing F11 and just keeps beeping, although sometimes it happens before spin cycle.
I did some research on F-11 codes and Vibration-- See if this helps:
The F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds.My research showed many people solving this problem with a replacement of the control unit or the relays inside of it.
The problem with the engineering and design of these washing machines was that they all vibrate excessively unless they are sitting on a floor constructed of a ton or more of solid concrete.
The vibration eventually makes either the motor serial/tach connector (or possibly one of the five relays in the control unit) intermittent, and the machine begins to throw error codes
I have found a good whack on the side of the machine seems to work. No kidding. Here's what happens: Stupid F11 flashes. I hit the pause/cancel button. It flashes the remaining time on the cycle. I hit the start button. Sometimes that just does it. If it doesn't I give it a whack on the left side of the machine, (if you're facing it), in the middle, about 6 to 8 inches above where the drawer is.
Let us know if we can help more--
Mack B
Jan 25, 2011 | Washing Machines
During the washing process the washer stops and the code F11 comes up. I have a Kenmore Elite He3t. Modle # 110.42926201
Hi, The F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds. This is so the washer can crawl slowly to tumble your clothes as well as spin at the ridiculously high speeds using the same motor. I would argue that "Jay's" is wrong about the door latch - there is a different specific code for that malfunction (I think it flashes F and DL). I wish it was the door lock - that's cheap, unfortunately, I think you are in for a MCU @ ~$200.
Take care
Jun 23, 2010 | Washing Machines
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Frigidaire Front Load Washer Making loud racket in last spin cycle
try pulling off lower acess panel. theres apump in rigth side corner . does it sound like theres something gaught in the squeeze the hose, try opening the door assy can you lift up on the inner basket. does it appear to have a bit of laterral movement???? how old is it???
Mar 13, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
344 people viewed this question
Sal De
fordexpert
Robert Rankin
