Question about Dell Dimension C521 PC Desktop
I need to create a boot disk for a dell dimension c521 PC
I have lost original system disk.Following a motherboard battery change I need to to create a boot disk for a dell dimension c521 PC
  • 317 Answers
SOURCE: Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Posted on Jan 09, 2008
  • 23 Answers
SOURCE: Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Posted on Jan 28, 2008
  • 157 Answers
SOURCE: My Dell Dimension 4600 needs to be reformatted.
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Posted on Jul 16, 2009
jepito
  • 216 Answers
SOURCE: I need to restore my dell dimension c521 back to
as soon as you turn the computer on hold down the CTRL key and press F11 try this
Posted on Sep 03, 2009
  • 570 Answers
SOURCE: Dell Dimension C521 - reseat the power button
I am providing you with the best link because the answer to be very long.Here you can get all the information on hardware for your PC and you can easily fix your problem.So please visit the link to fix your problem.
http://support.dell.com/support/edocs/systems/dimc521/en/sm_en/parts.htm#wp1121008
and there is also a manual from which you can get the information so also I am giving you this link.
http://support.dell.com/support/edocs/systems/dimc521/en/OM_EN/RP333A00.pdf
Please rate me if this solution works for you
Thanks......Have a great time.
Posted on Jul 10, 2010
Describe your Dell Dimension C521 PC Desktop Problem Unable to restore, no repair option in Advanced Boot Options, Symantec can't restore - says no factory settings found etc. Trying to get through to...
Even if your machine is out of warranty with Dell, if you're the original or legal owner having purchased it from the original owner you can order the original set of installation disks and all drivers and software that originally came with it. I've done this and they send them pretty fast!
http://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
Jan 13, 2011 | Dell Dimension C521 PC Desktop
My c521 powers up but will not boot. What can I try to fix the problem? Thanks
Check for internal missing devices and connectivities. check for disk media in the disk drives. The system unit has no hard storage drive.
Dec 21, 2010 | Dell Dimension C521 PC Desktop
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
How do I restore my Dell Dimension C521? I am
You need the C521 recovery disk, from Dell. Set the BIOS to boot from CD and start the system.
If it gives you the option of "Complete Reinstall" or "Repair", choose Complete Reinstall.
If it does not, or if it does not work - i.e., it always reads the disk and tries to maintain as much data as it can, you need to first wipe out the hard drive; there are many "Disk Wipe" utilities out there. I'd suggest using a boot disk such as DBAN (www.dban.org).
May 07, 2010 | Dell Dimension C521 PC Desktop
Diskette Drive Failure for Dimension C521
Most C521's have no floppy, if you have none:
boot to the BIOS, (F2 at boot) go to the drives setting, diskette (May be listed as floppy disk drive) set to NONE, exit and save settings
Apr 10, 2010 | Dell Dimension C521 PC Desktop
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Disk drive not found
It sounds like the hard drive went bad. Can you see the hard drive in the bios at all? When you try and boot the computer does it say drive not found? Try booting from the vista cd and see if you can start a new installation. If you can do the intallation the drive is ok. If not the hard drive is bad.
Jun 24, 2008 | Dell Dimension C521 PC Desktop
Dell Dimension C521 PC Desktop Logo
49 people viewed this question
Alun Cox
