Question about As Seen On TV Sewing Machines
The empisal em 250' needle get stuck between the sewing plates and wont move
He empisal em 250' needle get stuck between the sewing plates and wont move
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
Posted on Aug 20, 2008
bargainbox
  • 1388 Answers
SOURCE: tangle in bobbin area, stuck needle
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 13, 2008
  • 980 Answers
SOURCE: Need an Empisal sewing machine manual
As far as I remember that machine was made by Janome but you will need the model number
Posted on Mar 07, 2010
  • 35 Answers
SOURCE: sewing machine repair
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. You can learn how to repair different brands of sewing machine as well.
Posted on Sep 08, 2010
EM-250 - Empisal Sewing Machines giving problems not sewing moving ,feeding
Can only think of a couple of suggestions before taking it for service.
Make sure the drop feed has not been activated (pg 15).
Check that the stitch length is set high enough to actually move the fabric forward.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjV__iX29XZAhUB_GMKHcQzDwMQFggnMAA&url=http%3A%2F%2Fwww.empisal.co.za%2Fwp-content%2Fuploads%2F2016%2F01%2FEmpisal-EM-250-IM.pdf&usg=AOvVaw30CN-STT-2ozf8kueS1XTj
Mar 05, 2018 | Sewing Machines
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
When I select zigzag, the needle moves to the right, but when I sew, the needle stays in the right position but sews straight.
It has probably stuck even though never used and stored in the original box. You may want to have a sewing machine technician look at it.
Dec 04, 2017 | Sewing Machines
Hi I have a Empisal em-250 deluxe and my needle is hitting the bobbin casing how can I fix this
You need to have sewing machin3e repair shop check this problem, out may be it is out of time.
May 03, 2017 | Sewing Machines
Empisal sewing machine needle broken
try these 2 sites and ask them about the needles
a1sewingmachines.com
or
sewvacdoctor.com
Dec 27, 2013 | Sewing Machines
Need to replace Thread Tension Dial on my Empisal EM 250 DeLuxe Sewing Machine. Please help
Poppie, are you still stuck? I have a vintage Empisal and did the same thing - but I finally figured out how to put the tension back together. Check out my blog to see if you have a similar machine and I may be able to help.
makingmakesmylife.blogspot.co.nz
kind regards
KC
Jun 28, 2012 | Sewing Machines
Needle doesn't move
the problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Mar 10, 2009 | Kenmore 15208 Mechanical Sewing Machine
Needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Feb 27, 2008 | Brother CS-6000
Sewing Machines Logo
56 people viewed this question
Top As Seen On TV Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
