Question about Saws
How do i change the blade on my hitachi cj60v jigsaw?ive released the two grub screws and the blade wont slide in
  • 14 Answers
SOURCE: change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Posted on Jan 18, 2009
  • 211 Answers
SOURCE: cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
  • 10865 Answers
SOURCE: B&D 7580 Type 5 jigsaw. Cannot install blade
take your saw to any hardware store and they will sell you a blade that fits your saw and show u how to change the blade. not all blades fit all jig saws.
Posted on Apr 21, 2009
  • 16 Answers
SOURCE: change a blade on a jigsaw
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and retightened once the new blade is inserted.
Posted on Jul 07, 2009
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
What compatible blade do I need?
if this is a jigsaw blade there are 2 types on the market
one is held in by a grub screw and the other is held in by a collett that you have to pull up to release
there are universal blades on the market that will fit either
when buying blades consider the material type, thickness, finish, corners to go around
best find a good tool supplier and get advice for the blade and job
Jun 27, 2015 | Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
The blade on my jigsaw keeps flying out when i try to cut wood ive inspected the the place where the blade goes looks ok please help
There are diffrent blades for difrent makes ,Did you by the correct make e.g if its bosh by bosh blads .The slot might also be worn out if you used the wrong blade in it or the screw that holds it in is warn ,Hope this helps
Oct 01, 2014 | Saws
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
My Hitachi cj 110 jig saw blade keep falling out I have tried different types of blade What?s the deal with that? I don?t know why someone would put a quick release holder on a blade shaft of a power tool...
WOW everyone really cant figure out the problem??? Take your jigsaw blade and hit it with some coarse sandpaper or a dremel and knock the finish off the edges and sides depending on maker and it willl work just fine. The blade companys put a super slick finish on the blades. not the saws fgault.
Steven Melton
OKC
Jan 09, 2011 | Hitachi CJ110MV D Handle Jigsaw
How do I change the blade on a Bosch pst 54E Jig saw
There's an exploded diagram of a similar model here. Don't let it confuse you though. I mention it, because it shows the clamp screw which hold the blade in place (35 on the diagram).
Unplug the saw before you change the blade.
In the handle directly over the blade there is a hole with a clamp screw at the bottom. Use a long thin blade screw driver to loosen the clamp screw.
Once the clamp screw is loosened, twist the blade about 90 deg and you should be able to pull it out (don't cut yourself, by accident)
Put the new blade in with the same orientation and twist so the blades are facing the front of the saw.
Tighten up the clamp screw and you're good to go.
Be careful not to tip your saw over while the screw is loose. If it falls out and you lose it they're a bit of a nuisance to come by.
Jun 14, 2010 | Bosch Skil No.4230 - 01 Single Speed Jig...
Change a blade on a jigsaw
Jul 05, 2009 | Makita Jigsaw Blade
Saws Logo
63 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
