No Amplified Sound Coming Out...
I got an Onkyo CP-1022A turntable for Christmas but when a record is played, there is no sound coming out of the two AV cables that come out the back of the turntable. I know that the record player itself works really good because when I listen to it really close, there is music but it is not being amplified out of the cables I hooked up to my sound system from the turntable output cables. Do I need to purchase a new integrated amplifier and replace the old one or is this just a wiring problem?Thanks
  • sweetspirit Jan 05, 2009
    Bought a Yamaha p-550 turntable to play with our system. Spent hours hooking it up; can hear the music quietly but can't get volume. I think it might be the needle or the cartridge because with volume turned to max, sound is barely audible. email me at sweetspiritministries@gmail.com
    President:
  • 948 Answers
Http://www.mcmelectronics.com/product/MCM-CUSTOM-AUDIO-40-630-/40-630
Turntables need a preamp due to their very low output compared to modern components. The link above is the one I use. Try connecting to your receiver's phono input if you have one, also try the aux input. If neither of those work, obtain a preamp and you will soon be scratching with the best of them.
Posted on Jan 06, 2009
No sound coming from turntable
Things to check:
1. is cart connected to arm, or are wires loose?
2. Is turntable connected to rest of system, or are wires loose?
3. Did this ever work, or is this a new connection? If new:
A. Does rest of system actually have a 'phono" input? If not, you may need a "pre-amp" to boost phono signal.
Jun 01, 2015 | Audio Players & Recorders
Automatic turntable adjustments
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Mar 28, 2014 | Audio Players & Recorders
Shaky sounding records
Some things to check:-
Is anything preventing the turntable from rotating smoothly, this would cause a judder.
Perhaps the records are sliding on the turntable, a rubber mat will cure this.
Ensure the record player is on a level surface.
Dec 27, 2013 | Crosley Cr704 Turntable Am/fm Radio Record...
Connect Onkyo CP-1020F Turntable to Theater System?
Yes. It needs to have Line Level (slightly amplified or pre-amp'd) before your home theatre system can 'hear' it.
Oct 06, 2009 | Audio Players & Recorders
Why can't I hear any sound when I record from my turntable conver
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Jul 03, 2009 | Audio Technica AT-LP2D Turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Jan 29, 2009 | Crosley CR248 Turntable
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Nov 28, 2008 | ION Audio Vinyl Recording Turntable
** sound
First and foremost, make sure you plug into directly to the PHONO input of your receiver. If your unit does not have a PHONO input, then you wont be able to hear much coming from the unit. The PHONO input is a pre-amplified input, and this turntable requires an amplified input in order to transmit it's signal correctly. Just using an AUX or LINE IN will not have enough power to increase the signal of the turntable. You have the option of purchasing a PHONO PRE-AMPLIFIER (range in price from US$15-30), or purchasing a new receiver with a PHONO INPUT!
If you have it connected to your phono input, and still no sound, your turntable may have either faulty RCA cables (red/white cables), or a bad tonearm - in either case will need to be replaced.
Hope this helps.
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 09, 2008 | Technics SL-1200MK2 Turntable
377 people viewed this question
 Grubhead
Grubhead
