Question about Fanimation Islander in Oil-Rubbed Bronze with Standard 3 Speed Pull Chain
Won't turn on
Went on 1 week vac. all three fans were turned off. when I returned, one of the fans won't turn on? I have power........it just won't operate.......tried pulling chain........tried breaker switch........pushed the blades to help start.....but no luck. Does it take oil? Is there a lifetime warranty? Please help......thanx, Barry
  • 7 more comments
  • bholz1 Jan 02, 2009
    I have three fanimation islander fans which were all turned off while I was away for 1 wk. Upon returning, one of the fans won't turn on.....I have power....I tried the breaker switch......I tried tapping the motor as suggested......no luck! What next?????
    I bought the house with the fans included.......probably about 8-9yrs old.
    I take it that the condenser is inside the motor housing.......these fans are not cheap.....would it be worth it to get someone to the house.....it hangs on a 12'post
    Tried to manually spin with no success
    Don't want to sound ignorant, but I can see no outboard condenser.....is it inside the switch housing.....again, I can't see anything except the motor housing and the switch housing.....no lights attached
    unless I have one of the three switch wall plate that has gone bad......there seems to be power.....but, anything is possible, realizing that the one switch could be bad
    Hello! anybody have another suggestion? thanx, Barry
    Not the answer I was hoping for.........but it seems to be the most probable......especially since we had dust all over the area......just had new wood floors installed, sanded and finished.........anything else I might not have tried?
    the answer to check power at the fan to make sure there is an active feed to the motor makes sense.......if power is there, then the motor is probably worn out......thanx to all, Barry
    Brigadier General:
  • 8,619 Answers
Hi! You tried pulling the chain but nothing happened. Now check the connections with black,black, and blue make sure the two black wires are firmly together.
Try spinning the fan with a stick and then switch it on and check all the controls.
Does the fan have a light? Does the light work? If both the fan and the light are not working, it is likely a connection issue. Lower the fan canopy and/or housing, and check to see that all the wires are connected firmly.
And, if still doesn't work then there would be a small cylindrical capacitor, check weather it is burnt or is there any kind of oil leaking through it. If so replace it with a similar rating Capacitor.
Posted on Jan 02, 2009
    Sergeant:
  • 311 Answers
Youv'e lost power.could be loose wire nut.youl have to check power at the fan.with lite switch on and go from their.tom
  • 177 Answers
Hello and welcome to FixYa!,
It sounds like the Fan Motor has Burnt Out or is Faulty.
You will need to replace the Motor with a new one!
Hope this is Your solution --P3NGYJ03
    Genius:
  • 1,142 Answers
All you need to do is manually move the wings after switching on the fan use a ruler or a stick to do that.
    Novelist:
  • 163 Answers
There is a condenser on the fan upside the motor need to be replaced with new one.
  • 1 more comment
  • ronny2051 Jan 02, 2009
    lifetime warranty supports only for 3 year.
    condenser worth only 4 or 5 usd ,, and the condenser is not inside the motor it is upside.
    Good Luck.
    ya its very cheap to get repair.
    Genius:
  • 1,268 Answers
How long have you been using it though? I believe there's a warranty for your unit
    Brigadier General:
  • 5,158 Answers
It's abit old fashioned ... but tap the motor abit with a hammer or ruler .... and NO not hard
  • Roberta Smith
    Roberta Smith Jan 02, 2009
    how have you confirmed there was power to the fan ?
  • Roberta Smith
    i would suggest that the wall switch has indeed gone bad as i can't see any other logical reason for that fan to have failed. if you have a way without getting electrocuted of course to test the voltage at the fan itself that would certainly narrow down the problem.
    Robert
The fan operates correctly, but I cannot get the lights to work. There are 4 candelabra bulbs. The bulb receptacles have 110 VAC on them. Once bulbs are installed, the voltage to bulbs drop out.
There are two ways that ceiling fans are wired.
1. you turn on the wall switch and then you have one pull for the light (on and off), one pull for direction (clockwise, anti-clockwise) and one pull for three speeds and off.
2. you turn the wall switch on and the light comes on. There are two pull switches one pull for direction and one pull for three speeds and off.
Check your wiring from the installation instructions, the wiring in the ceiling.
Sep 29, 2015 | Dryers
Harbor Breeze ceiling fan lights won't work
Check light wire in ceiling to make sure it didn't come loose.
Jun 06, 2013 | Dryers
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Nutone model nsp130 fan won't turn off
Does it have a remote? If it does change the frequency in both the transmitter & receiver.
Feb 06, 2013 | Dryers
Hunter fan light switch won't turn off light
by looking at the sw. it looks like u can only put it to a low dim and not off and the button at the bottom is all off including the fan if this is correct u should be able to change to a different kind of fan sw. combo or even a remote style that comes with a receiver ,also your fan should have three wires at the box a light wire "blue" a fan wire "black" and a neutral "white" oh and a ground "green" in order to switch these separate u need those 3 wires at the sw. also . but with a remote u only need the hot and neutral it hooks up in the box or canopy of the fan to the receiver all wires are marked for easy installation turn power off to be safe u can install a regular sw. to over ride the remote and turn power off at the fan .......its alot i know but hit me up if u need more help.
Mercedes Parts
May 25, 2012 | Hunter Ceiling Fan Light Switch Control
I found my Hunter Original fan's switch to be frozen, so I went in search of a replacement. I bought a 3-speed switch with similar wiring (red, blue, and black wires). I wired it up and turned it on. ...
I think you have the power wire mixed up. Your power supply to the switch should be black. And in most cases goes the the L-1 labeled on the switch. If you have trouble finding the power just plug the wires in and use a simple light or voltage tester. Once you have the power wire just touch each wire 1 at a time and you can tell the speeds. Once you have the speeds hook them up to low being 1 med.2 high 3. Then your done
Sep 11, 2010 | Hunter 23852 Classic Original Ceiling Fan
Just tried to install the fan and light, it doesn't work when power is connected. I have 2 white house wires, none black. I have rechecked the connections, no power to the fan
the white wires are returns they dont supply power .. you may have to take the fan back down in order to find the black or red wire that supplys AC power .. a red wire would come from a wall switch .. the black wire would usually be 120 VAC .. be careful .. you must first turn off power before working with that live wire .. the white wires are always paired with a black wire and a bare wire (safety ground) .. perhaps the black wire just got covered up when the fan was installed .. the black (or red) house wire should be connected to the black and blue wires of the fan .. the white wires should all be connected together .. the bare wire should be attached to the green wire or bolted to the fan housing ..
Jun 22, 2010 | Hunter (25417) Ceiling Fan
Lights are out
The manufacturer is King of Fans. Their number is 800-330-3267.
Nov 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Aug 06, 2008 | Hampton Bay 24002 Ceiling Fan
Fanimation Islander in Oil-Rubbed Bronze with Standard 3 Speed Pull Chain Logo
Top Fanimation Dryers Experts
Paul Bade
Fan Fair Of Boca
Fan Fair Of Boca
Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
