Question about InFocus ScreenPlay 4805 Multimedia Projector
Losing image the left side of projected picture is dark and this 6 - 8" strip runs the height of the screen. problem started about one month ago and the strip has grown from 1 inch to what it is now.
I have a very simliar problem, i found a way around it by changing a seeting in the advanced options. somehow, my horizontral position was changed from wahtever the default was to 88, which set it too far to the left. set it back to 50 and while the image was good, the menu is still in the oddly placed area....oh well....hopefully it's not the bulb, i just changed the damn thing less than a year ago
Posted on Jun 02, 2007
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
We have an InFocus LP70+. we have had a dark strip along the right side of the projected image. That dark strip has spread across so that now we only have a strip of the image along the left side. Not sure...
the light tunnel (integrator rod) has collapsed and needs to be replaced. you could either buy the part from an infocus service center or send it in to one for repair. it is, however, a pretty involved repair. if you are mechanically inclined, then try it. otherwise, send it in. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 10, 2009 | InFocus LP70+ Multimedia Projector
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Blurry double image on the edge of the tv...
If you have tried to adjust the convergence on your TV within the menu feature then typically you do have a convergence problem. Check out this video to be sure...
Apr 16, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
InFocus ScreenPlay 4805 Multimedia Projector Logo
96 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
Marvin
Marvin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
