Question about Whirlpool Duet GHW9150P Front Load Washer
My washing machine runs forever. It takes like 2-3 hours to get through a 45 minute cycle. It also comes up with suds alot. I am using the HE detergent what is wrong???
I had the same problem with my front load washer. A technician came and fixed it and showed me what to do in the future if it ever happened again. I had to take off the front bottom panel, and on the lower right side there was a screw-top about the size of a golf ball. When I unscrewed it -- have you a bucket ready -- water would drain out and the drain would be stopped up with all kinds of stuff -- chapstick containers, baby socks, q-tips, toothpicks, hair, etc. Once this was unstopped, I would screw the top back on and it would be good for a couple of months. Whenever it started taking a really long time for the clothes to wash or the clothes were coming out too wet, I knew the drain was stopped up again. This is probably also the cause for the suds -- it's just not draining properly. Hope this helps -- I had SO many problems with my front load (with the biggest being stinky laundry), I got rid of it and got a basic washer and dryer.
Posted on Jan 03, 2009
Fisher and Paykel washing machine
Without being smart...buy a new machine. It sounds as though the timer is dying...therefore slowing down...therefore extending cycle times. If that's the case, a new timer will cost about half the cost of a new machine.
May 06, 2012 | Fisher and Paykel Washing Machines
Code f02 comes up. washer will not spin.
F02 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F09 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
Nov 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Running two hours for a 40 minute cycle
if you use to much soap the unit can go into suds lock and keep trying to get it out
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet ----"SUD" and "F02" code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Aug 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Keeps washing
If you are using a front load washer, never use more than one tablespoon of HE laundry soap per load. Now, to get rid of the suds you have: Get a package of Phyzeme (spelling?) tables for stomach gas. Cut about four of the capsules open and add the liquid contents to the washer, then resume wash. That will knock the suds right down without having to run about 10 rinse cycles through the washer.
Jan 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
F35 Message on Brand New Washer
suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal De
