Question about Optoma RD50 50" Rear Projection HDTV-Ready Television
I turn on the tv but I get no picture (black screen). A sound starts when I turn on the tv. The sound ( like a humming noise) fan perhaps which goes up and down for about a minute then the tv shuts off and the lamp indicator goes on solid red. I have replaced the lamp. Prior to changing the lamp the tv would be shut off for an hour or two and when I return to the house to turn on the tv it would not come on. At times it would come on the next day.
  • Anonymous Jan 31, 2009
    I recently replaced my lamp.  The TV picture will not come on.   If I unplug the TV, and plug back in the TV will come on( sometimes, but not always).  There appears to be some type of "protective" circuit that is keeping the lamp from kicking on.
    I am having the TV repaired next week.
Sounds like a problem with the color wheel. Unfortunately the color wheel is located inside the light engine. According to everything I have read, the only thing you can do is replace the light engine. You are better off replacing the TV. The light engines can run form $750 to $1400. Which is ridiculous!
Posted on Jan 20, 2009
My Samsung HL-S5065W will turn on, it makes a humming noise. The picture comes on after a 1 minute or so the screen will go black and the tv shuts down. What could this be?
Hi,It sounds like you might be
experimenting a color wheel problem.The
color wheel is a rotating disc that has a
gamma of colors it spins at high rpms.The
light of the lamp goes through it to create
the colors on your tv.When it starts to go
bad you will hear ,humming,buzzing,high
pitch noises ,you might also experiment
color distortion ,black and white
picture.Here's a link that will help you
replace it:
g/bp96-01579a.php Part # is BP96-01579A and you can find it here: Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Humming noise
There are only two moving parts in this set. The fans and the color wheel. Typically when the color wheel starts to break or go on the fritz, the tv stops working. Count your blessings you've still got the picture. Open the back and turn the tv on. The color wheel is located on the optics block tray. The fans are very visible with the back off. Stop the fan for a second and see if the sound goes away. If not, you might want to start looking around for a replacement color wheel. is a good place to start. Sometimes carries them too. Be aware that there two different wheels available. If the fan is the culprit of your problem. Radioshack will likely have a replacement for you. If you need further help, post a comment or email me and I'll send you pictures of what to look for.
Good luck.
Mar 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Deep Humming Noise
if the noise continues after you power down its the cooling fan
Jan 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Optoma RD50 50" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Optoma Televison & Video Experts
Are you an Optoma Televison and Video Expert? Answer questions, earn points and help others
