Question about Mitsubishi WD-60638 DLP TV
Mitsubishi dlp 60 inch wd60638, sound but no picture, green light, no red indicator light?
No picture but it does have sound?
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WD-52525 red light no picture or sounds, lamp has been replaced.
The hardest part is getting the chassis block out. But if youre mechanically inclined and follow the illustrations and label all the wires you unplug, its not that difficult a job. The soldering isnt very difficult as theyre just capacitors. The chassis is contained inside a metal container and has to be removed as a unit then opened up to get to the PWB PC board.
Posted on Jul 06, 2008
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
Hear a pop like a firecracker and then no picture
It is likely that the bulb has failed. The bulb can be removed as an assembly from the rear of the unit. Carefully inspect the lamp and confirm that the glass bulb has failed. the pop could be the bulb fracturing. Careful for broken glass. Suggest that you buy a direct manufacturing equivalent. I have found they are the brightest.
26120369-qhrtjxzbaepf4lgqc41ptsvr-3-0.jpg You can buy just the bulb or the whole lamp assembly as pictured above. I recommend buying the assembly
\The link is from the owners manual providing the instructions to replace lamp.
http://www.manuals365.com/swf/mitsubishi/638-c10_bib.html?page=28#manual
Hope this has helped?
Mar 06, 2016 | Mitsubishi WD60638 60" inch 3D Ready DLP...
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
My tv will power up with the with no sound for about 60 seconds then shuts off with grin flashing light for about 60 seconds the red light comes on amid stays on. What is the problem? The fan comes on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 30, 2014 | Mitsubishi Cinema WD-73640 73-inch 1080p...
How do i reset my WD60638
This model will or may have the soft reset: power on, menu 1,2,3 enter.
It will have a hard reset that requires a 4 digit number code as well that is available only from Mitsubishi or a authorized service center---they do not want that made public as one wrong move......
Oct 30, 2012 | Mitsubishi WD-60638 60-Inch 3D-Ready DLP...
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
I have a mitsubishi dlp 915p020010 and when i turn it on the green light gomeson to indicate that i have turned the tv on but i dont get a picture or sound then about 30 seconds later the light turnns red...
Power supply and DM caps need replaceing very common with the V26 DLP's The V26 DM/Power repair kit from www.tvrepairworld.com should solve that and the kit also contains instructions for the repair.
Aug 27, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WD-60638 DLP TV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
