Question about Sharp R-1500 Microwave Oven
Sharp r1500 microwaive
Everything on the oven works except the oven. I was boiling water and had the exhaust fan on, went to pop some pop corn and after starting the oven there were a couple loud pops and it was not the corn. Since then the oven is not heating and sounds as if it is straining when we try. All the lights controls, fans and such work. is this repairable? The warranty said the magnatron tube is covered for 7 years. could that be the problem? either way is it worth having repair come out?
  • Sharp Master
  • 9,149 Answers
Sine you heard a pop. I would suspect the high-voltage rectifier diode.
But it could be the magnetron, possibly grease got past the waveguide cover and caused some arcing.
You can usually save about $50 or so on service by pulling it down form the wall and taking it in for repair service.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
    Problem Solver:
  • 15 Answers
Indeed, sounds like the magnetron is shot. Not a big deal, I've replaced them before. But unless you know what your doing, don't! If under warranty, get a service tech out. Check on the service call charge ($) first....it may be cheaper to buy a new micro!
Posted on May 12, 2007
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
MICRO WAVE DOOR FOGS UP WHEN USING IS THAT NORMAL
A Microwave Oven works by heating water/moisture in food: if the boiling action (e.g. when boiling water) is greater than the oven exhaust fan can cope with, then the inside will steam up and fog the door glass: this is usually OK and 'normal' (this is actual the advise in cleaning up the interior of a microwave oven - steamy soapy water - see your manual).
Hope it helps.
May 16, 2011 | Hamilton Beach Microwave Ovens
My Sharp carousal microwave model R 1482 goes on and off on its own. When cooking the steam from boiling water will set the micro off like I am pushing buttons on it.
If it's just the hood vent exhaust fan coming on, that's normal due to a temperature sensor (the hood vent exhaust TCO / thermostat).
If other functions on the microwave are coming on, then the keypad and / or controls may be shorting due to moisture and / or heat, and that needs to be addressed.
You should always run the microwave oven's hood vent exhaust fan whenever you're cooking on the stove top.
If you do, and the trouble persists, I would suspect the controls.
The service manual is at our site and we have uploaded it here to help you.
You can order any needed parts from the Sears Parts Direct Web siteimage-4235112-10659157 or Encompass here or you can call them toll-free at 866-779-5835.
Let us know if we can help you further.
Jan 09, 2011 | Sharp R-1482 Microwave Oven
The microwave quit working. I could still use the timer and the fan. After a year, I had a pot of water boiling on the right back burner of my cook top and the microwave exhaust fan came on. I could not...
I think a bad connection in a lucar styl plug is the problem.
Check all of the connectors that come from the switch/control pannel and the magnetron's transformer.
Make certain that it is not still charged up at a lot of voltage in the capacitor is lethal!!!!
Oct 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Boiling water caused large "Pop" sound/microwave not working now
I would guess that the boiling water may not have been the cause ...
If you are lucky ... try this first:
Unplug or turn the circuit breaker off (if it is a built in unit). Wait an hour and then repower.
Odds are that will not clear things up ... but it is easy to try. Probably one of the electronic internals broke.
A number of different internal component problems could cause this heating failure in the microwave. It could be the magnetron, the high voltage transformer, the PC board, the diode, and the capacitor. This type of problem will need to be diagnosed and repaired by a service technician. Microwaves are inherently dangerous to service. This type of repair is not something that you want to try to do yourself. Internal capacitors in the microwave can retain a lethal electrical charge even when the microwave is completely unplugged. A microwave radiation leakage test should be performed on the unit using proper testing equipment following any internal component repair.
Jan 25, 2018 | Sharp R-1480 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Crackling and popping sounds when you heat up food
thats normal water expanding and boiling off from the microwave boiling those tiny water pockets in food... sounds like popcorn sometimes.
Cover your food with a paper towel to avoid spatter on the ceiling of the microwave when this is happening.
Sep 12, 2009 | Sharp Microwave Ovens
Whenever anyone uses the stovetop to boil water, the steam seems to affect the microwave and causes it to turn on by itself and the panel buttons will not work
did it come with the exhaust fan under it? if so just turn it on when boiling water if it didn't try to find one that goes with the unit and hve it installed, this is theonly way to fix the problem
Jun 27, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave oven inoperative
check high voltage section, check magneatron, diodes, etc.
Nov 02, 2007 | Sharp R-1480 Microwave Oven
Sharp R-1500 Microwave Oven Logo
104 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
