Question about Sharp CD-BA300 CD Shelf System
Sharp cd ba 300 cd drawer will not open and displays error er cd11
zair
  • 82 Answers
SOURCE: Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Posted on Mar 29, 2008
  • 4234 Answers
SOURCE: ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Posted on Apr 07, 2008
KMusselmann
  • 247 Answers
SOURCE: Sharp XL-HP505 CD players won't open.
I don't know what the code is but have you pushed the reset button. If you do push it you will have to reprogram the unit. Otherwise it will have to go in for service
Hope this helps
Kurt
Posted on Mar 18, 2009
  • 4234 Answers
SOURCE: I tryed to have additonal speaker on my sharp
The output amp section for your system is not designed to run more than the speakers that come with it. By adding more, you presented too low an impedence load to the amp and overheated it. This occurred too quickly for the internal protection circuits to kick in to prevent damage to the outputs. This unit will now require that the outputs be replaced. These are not the easiest units to work on, so I would not suggest that you attempt this repair yourself. Expect a parts cost in the $35 range for this repair. Dan
Posted on Jun 09, 2009
SOURCE: The 3-Disc Rotary Changer will not eject. Error ER-CD11 appears.
notice sharp 3 disc rotary changer en français; svp
Posted on Nov 26, 2010
Sharp ER-A460 display says Close Drawer and drawer is closed. Advice, please.
Could be just a faulty switch that is broken in the open position, even though the door is closed.
May 26, 2018 | Sharp Audio Players & Recorders
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
SHARP ER-A410 CASH REGISTER DRAWER WON'T OPEN
Does it open when you print a Z report? The most common problem with these was either the drawer wiring or drawer solenoid failing.
If anyone needs more information, the Sharp ER-A410 and ER-A420 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Oct 20, 2011 | Casio Parts Cash Register PC Desktop
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
i had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Dec 05, 2008 | Audio Players & Recorders
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Sharp CD-BA300 CD Shelf System Logo
53 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
