Question about Philips Gogear SA2RGA04KS Mp3 Video Player
Error code 3 on my gogear vibe 4gb mp3
I am getting a system error code three when I charge my go gear. It will not play, or do anything I recognize as a function of an mp3 player. Do I need to use the disk that came with it and re-format it or is there a free web-site that may help me fix it? Can you help please? My e-mail address is gwelker@dmail.dixie.edu Respectfully Submitted, Gary Welker
SOURCE: what video format does gogear vibe use?
well its kinda odd but so far the only format im having any luck with working it is .smv to covnert ur vids to .smv go here" http://www.soft29.com/freeware/smv_converter.htm " hope this helps
oh and btw im not saying there arent more formats but this is the onethat works for mi go gear vibe
Posted on Nov 25, 2009
shadow83
  • 496 Answers
SOURCE: System File Error on Phillips GoGear Vibe
you should be able to put it into recovery mode by holding the volume up button while hooking it up to the computer after that you should be able to do a recovery on it using the software provided with the player
Posted on Dec 07, 2009
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
Posted on Jun 18, 2010
firesnake09
  • 2923 Answers
SOURCE: whenever i try to play
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Posted on Oct 31, 2010
Testimonial: "thanks"
  • 3 Answers
SOURCE: what video format can I put on my gogear vibe 4 gb
just use the songbird program that comes with the device, update it from the net, then drag n drop .avi and .mp4 files (this is all i've tried so far..). it will convert my 700mb avi movie files and put them on the device.
Posted on Nov 29, 2010
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Aug 05, 2010 | Philips GOGEAR SA6045 MP3 Player
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
How do i put pictures on phillips go gear vibe 4Gb mp3 player?
hi my philips gogear 4gb vibe wont download pictures off my computer. but when my daughter plugs up her new ipod, it downloads them. can you please tell me why this is and how i caqn get pictures on mine? thanks
Feb 04, 2010 | Philips GoGear SA178 MP3 Player
What video format does gogear vibe use?
my mp3/4 does not play video when you click on vidio it says video format not supported
Jun 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips Gogear SA2RGA04KS Mp3 Video Player Logo
144 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
