Question about Health & Beauty
Motiontrendz ripper 6volt motor scooter back wheel is stuck.
2 Suggested Answers
  • 39 Answers
SOURCE: schwin scooter not running properly
If the battery is old its likely that it needs to be replaced. Also, if batteries sit in the cold in the winter or are exposed to high heat they can be damaged. Try checking out http://www.batteryinternational.com/electric-scooter-batteries.html for a scooter replacement battery.
Posted on Jun 23, 2009
My scooter slows down then goes back up again
The problem you have got is the throttle pot is faulty. Get this replaced and it will be fine
Jun 19, 2015 | Pride Mobility Products Celebrity X...
Rear whheel is draggiung off an on on my 3 wheel electric scooter
Check under the wheel and inside the wheel case to see if someone's undies got stuck under there.
Also check to ensure any neutral/freewheel/ez move/ type levers are in the full "motor powers wheels" position.
Feb 02, 2013 | Golden Technologies Companion II Travel...
I have a motion trendz, 3 wheeled scooter 6volt and I can't find the spot where the charger goes into on the bike.
you have to remove the phillips screw at the rear of the seat and t5his will give you access to the battery so that you can plug the charger in
Dec 26, 2012 | Health & Beauty
In Drive position the wheels are locked and in neutral the wheels remain locked and will not spin or free wheel. In drive with the battery in the unit just clicks but does not move, everything works such...
I would suspect that the brake is not releasing causing your problem. When you place the handle in freewheel and you can't push the scooter easily then the brake pad is stuck on the motor housing. If you are able remove the seat and back cover remove the drive wheel on the side of the scooter nearest the freewheel lever usually the right side. you should be able to see the brake attached to the end of the motor with 3 or 4 hex head screws. take the brake off the end of the motor and carefully leave the wiring attached ( don't break or remove the wires going to the brake or the scooter will not run at all) remove the brake and place or tie it up where it won't fall or drag. Put the drive wheel back on and turn the scooter on and see if it will now move. If it moves like it should you will have to replace the brake. You can drive the scooter like this but remember you do not have brakes so the scooter can roll backwards or forward when not on and especially on ramps Hope this helps
Apr 23, 2011 | Drive Medical Drive Falcon 3 Wheel Compact...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
My four wheel golden electic scooter is fully charged but went from fully operational to just clicking and not moving at all. Can you help?
Hi. I have had this problem on many machines. It is normally a stuck brush in the motor. This stops the motor from going. The click you can hear is probably the brake solenoid releasing.
Can also be a faulty connector in the motor or battery leads.
Good luck. Neil.
Jun 09, 2010 | Golden Technologies Avenger 4 Wheel...
I have a legend pride four wheel electric scooter. It does not run anymore. We checked the batteries and they are good and we charged them. We also went through all of the wiring and made sure the...
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
May 09, 2010 | Pride Mobility Products Pride Legend XL -...
Health & Beauty Logo
122 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
