Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice despenser won't sut off.
Removed water and ice dispenser assy. to replace broken water lever. Now the ice dispenser won't shut off. I had to remove the circut board and disconnect the tape connection but I can only see one way to put back. But every time I reconnect the ice dispenser turns on.
  • Jeff Bashor
    Jeff Bashor Jan 04, 2009
    I had to replace the wire ribbon & ended up having to unhook the wires for istallation, when we hooked them back up the auger wouldn't stop. my model is a frigidaire frs6lf7fb7. please help.
    Sergeant:
  • 311 Answers
Hi ggammon the dispenser is activated by the paddle that you place your glass against,then touching a micro switch .so i'd say you've got somthing amiss there and i would think only eyes on the ground can see what that is.i just said a prayer for you and you'll have to go back in there.in Gods service,tom
Posted on Jan 02, 2009
My water dispenser is INOP.when lever is pressed only a hum can be heard but no water. Removed water filter and water shoots out inlet. Attempted to blow on inlet portion on water filter and no air flowed...
The water line may be plugged or frozen.
Remove all the food and put in another freezer and shut the freezer off for 24 hrs and see if it works then. Is there ice cubes stuck in the despenser ? If so clear them out. May be the jammed ice cube my not let any water through.
Jan 30, 2015 | Refrigerators
Won't make ice but will dispense water.
the gear assy in your ice maker is proably bad, it is less expensive to replace ice maker as a complete unit. 10 minute fix
Mar 03, 2013 | Freezers
Frigidaire side by side water line clog
Hi -I understand that your unit is still not producing any ice or dispensing water. Some of the following steps you have already confirmed. I suggest confirmed the steps below and see if any is helpful :
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 10, 2012 | Refrigerators
Ice maker not working
If your ice maker has stopped producing ice completely, try checking the following:
Oct 08, 2012 | Frigidaire FRS23W3A Side by Side...
Samsung rf4287hars ice dispenser doesn't work
The whole unit must be removed and unplugged. There is a screw in the bottom near the dispenser opening. Remove this screwn and then take a butter knife and start prying the unit outword.
The lever that operates the microswitch may be broken and was on mine. This part is cheap plastic and breaks when over entended in the least. If the actuation lever is broken, you will NOT feel any resistance when pressing the Ice despenser and will push on through to dispense water. Problem is there is NO fix for this except replacement and Samsung will not pay for it.
I fashioned a piece of bailing wire in place of the lever that will act the same and have a little spring incase someone presses to hard with their cup/glass. Yes... its bailing wire and works great. You must drill through the middle of the broken support, fashion the wire, coat with super glue and put in position pretty quick. 43e0da13-0ab4-425d-8cad-f17e16cccb58.jpg
If you find a small plastic piece on the floor and your ice maker stops dispensing.... I think I know your problem.
Oct 06, 2012 | Samsung RF4287HARS French Door...
Ice maker not making ice
Hi - If your ice maker has stopped producing ice completely, try checking the following:
Oct 01, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
112 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
