My acer aspire 5253-BZ893 is having some booting problems
  • 256 Answers
SOURCE: Acer Aspire 5315 Vista Windows boot problem
have you checked if your pc is compatible with win7? use this to check it: http://www.microsoft.com/windows/compatibility/en-us/default.aspx
and if it is, try to do a clean install. boot from the cd. insert the disc. restart pc, as soon as it has power, press F12 several times and highlight cd/dvd drive or ODD using your arrow keys then press enter. it will load the cd from there. And that should work fine.
Posted on Apr 03, 2010
sandrew
  • 2961 Answers
SOURCE: Acer Aspire 3100 boot up problem
unless it is something more serious, first keep pressing F8 when you turn on the notebook and it should enter safe mode. When in safe mode select the operating system that is highlighted and then a screen will appear with options, one being 'Last Known good Configuration', highlight this and press enter. The system will reboot and start again in windows as normal hopefully. If you are not able to get a screen showing in safe mode there is something more serious wrong and it could be hard drive fault or motherboard, but if you can see the disc drive light flickering the system is loading and you may have a graphical fault.
Posted on Aug 10, 2007
  • 244 Answers
SOURCE: Boot problems with Acer Aspire 3610
do you have power ? if no, check your power outlet and ac adapter first, if both of them are ok, it could be your motherboard.
if you have power but no display, this is called no post.
reseat your memory. if still not working, use 1 memory and try to put it in different ram slot. and if this is still not working, your motherboard is bad
Posted on Jul 26, 2008
SOURCE: acer aspire 5220 booting problem
Try connecting to an external monitor. If it displays on the external monitor then the LCD is probably dead. If it doesn't display on the external monitor, its a problem with the video card.
Posted on Feb 26, 2009
ghosttechx
  • 72 Answers
SOURCE: i locked myself out of
Hello, If you cannot log on to Windows by using a particular user account, but you can log on to another account that has administrative credentials, follow these steps on how to do the trick: 1. Log on to Windows by using an administrator account that has a password that you remember. You may need to start Windows in safe mode (Which is pressing F8 at boot up).
2. Click Start, and then click Run.
3. In the Open box, type "control userpasswords2?, and then click OK.
4. Click the user account that you forgot the password for, and then click Reset Password.
5. Type a new password in both the New password and the Confirm new password boxes, and then click OK.
Posted on Mar 17, 2011
I have an acer aspire my son was playing video games and somehow reprogrammed it you cant access it because it says administrator even with the proper password
If it's an old machine with XP, download Ubuntu 14.04, put it on a flash drive and boot from the flash drive. You can make it dual boot or just Ubuntu, ad can access all that's on the computer.
Oct 06, 2014 | Acer Aspire 5253
Flash bios on acer aspire 5253
Go to Acer's website to get Bios updates.
Sep 23, 2014 | Acer Aspire 5253
Boot disc for acer aspire 5253
try backing up a full back up of your own windows,ask your laptop todo a full back up,that way if anything happens to your windows you can always use the disc to put it all back.
May 31, 2014 | Acer Aspire Computers & Internet
My acer asp[ire 5253-bz893 wont turn on
Need more info. Unplug , remove battery, plug in reboot. Post what happens next? Is the transformer (brick) on the cord getting warm? Have you tried another cord/charger with the EXACT same specs?
Jan 11, 2013 | Acer Aspire Computers & Internet
PXE-MOF check cable
PXE is network boot. Go into BIOS and make sure it is detecting your hard drive. If it doesn't then the drive is potentially bad and will need to be replaced.
Dec 29, 2012 | Acer Aspire LX.RD502.030 5253-BZ893...
Hard disk problem
If you are getting read errors after running a "chkdsk" and a "scandisk" replace the drive. Drives are much cheaper than lost data.
Jul 19, 2012 | Acer Aspire LX.RD502.030 5253-BZ893...
Turn wifi on
Hello abthomas930,
I think your Wireless Zero Configuration might be turned off.
to reset it and turn it on, do this:
if you can press WindowsKey + R together, it will be a shortcut for you,
but if not, do this:
Click on STart, click on All programs, click on Accessories, Then Select
Run.
On the page that comes up type the following:
1.) sc.exe config WZCSVC start=auto
2.) net start WZCSVC
This should reset and restart your wireless settings.
Let me know how it goes after you have tried this, so that we will know
what to do next.
Goodluck and Thanks for using Fixya.
Jun 05, 2012 | Acer Aspire LX.RD502.030 5253-BZ893...
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
