Question about Gigabyte GA-8I865GVMK Motherboard
What graphics card this motherboard will support
Respected sir, i bought a gigabyte motherboard,i am ineed of a graphics card. So "WHAT KIND OF GRAPHICS CARD CAN I USE? & ALSO SECIFY A EXAMPLE FOR THAT TYPE!".. THANK YOU,
  • Anonymous May 02, 2009
    I bought a Gigabyte graphic card and need to connect it to mother board.
  • 944 Answers
Here is the link to the product support page for your motherboard; http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1732 The motherboard includes an Intel Extreme graphics card built in - the necessary drivers are available throught the link above. Here is the link to the manual for the motherboard if you need it; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_ga-8i865gvmk_e.pdf Page 1 gives all the possible expansion graphics cards you could use - the gigabyte AG325(G) is recommended. Hope this helps :)
Posted on May 12, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh May 12, 2007
    Second look says that the information provided by gigabyte is incorrect - the MB has no AGP slot and the AG325(G)is an AGP card so will not work. td123's suggested model sounds fine.
Gigabyte did not put a special graphics slot (AGP, PCIe etc) on this corporate series board. It has good internal graphics support. If you would like to run two monitors, it appears that one choice is the CHAINTECH P-FX20 256MB Geforce FX5200 256MB 128-bit DDR PCI Video Card, based upon user reviews at NewEgg. You may need help getting both graphics adapters to operate together. Typically, there is a jumper on the card that disables "Primary VGA" mode. Your OS should boot using the on-board adapter and then you can tell the OS that it should "Extend the Desktop" to the second (PCI) adapter. Your results may vary.
PLEASE HELP .QUESTION BELOW
Did you move the lead between the computer and the monitor onto the new board you installed?
Mar 09, 2015 | Computers & Internet
My Dedicated Video Memory Is 64MB. How to i increase dedicated video memory.I Use gigabyte Motherboard
Hello here is the gigabyte homepage:
http://www.gigabyte.com/support-downloads/support-downloads.aspx
The manual can be found by, selecting the mainboard number.
The video memory can be changed in the bios settings, but can probably only be decreased to a lower setting.
I guess the 64 mb, is the max memory setting.
The solution is to add a better graphic card, on the mainboard for better performance.
A graphic card can be bought in a computer shop, or online.
You just have to know, what socket the mainboard has.
There is 2 different ones: AGP or PCI-E slot
Good luck
Mar 23, 2013 | Gigabyte Computers & Internet
VGA Support?
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#sp
Your mainboard supports 1 x AGP 8x slot ( the green slot )
The new PCI-e express does not fit the socket.
When you add a bigger graphic card, you will probably need a bigger power supply.
I recommed a 500 watt or bigger.
Most external graphic cards uses 150 to 250 watts, depending of the size of the card.
I also recommed ATI/AMD graphic cards.
Such graphic card, can be bought online, or in a computer shop.
Good luck
Feb 07, 2013 | Gigabyte GA-8I865GME-775-RH Motherboard
Dear Sir, Gigabyte 8VM533M-RZ Motherboard shows 640x480. I can not set to 800x600 or above and permit for limited job. Is there any solution? Please help me. -----Harun
Hello sir,
From the motherboard brand you have, below are the technical specifications: Chipset: VIA ProSavageDDR P4M266A Graphics: ProSavage8 Graphics engine.
The reason you cannot set the screen resolution in Windows XP above 800*600 is because you do not have the appropriate drivers installed for your machine, i.e for the VIA ProSavage8 Graphics card. To solve this problem,you need to download and install the necessary drivers. You can download them from the link below: http://ranger.s3graphics.com/swlib/
Just accept the license agreement and browse through the FTP folders for the S3 ProSavage8 graphics driver(Alt. called ProSavageDDR).
Hope this solves your problem.
Feb 09, 2011 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Kind attention tech support, I have this CPU- INTEL Pentium 4 Processor, LGA775 Pkg, 2.66 GHz, 1MB L2 Cache, 533 MHz FSB MERCURY Main Board PNMCP73V, 1GB DDR2 667MHz Kingston DDR2 RAM SEGATE SATA...
You could put either of the graphics you mention in that motherboard providing you get the PCI-Express versions of them.
The motherboard will support a DDR3 structured graphics card in all cases at that is determined by the card not the motherboard as you get specific drivers for them which come included with the card or you can download the latest drivers from ATI or nVidia's support websites.
That motherboard will also support a gigabyte plus graphics card.
Kind regards.
Jul 13, 2010 | Computers & Internet
I believe that my agp slot went bad so i bought a new video card that uses a pci slot instead how do i access bios to configure this when recieving this error code at post 1 long 2 short gigabyte...
Hey,
1 long 2 short is video card failure.
if you had a pci slot card inserted in the agp slot and you powered on, the motherboard may be damaged.
Feb 18, 2009 | Gigabyte Computers & Internet
Gigabyte 7VM400M-Rev.1 Onboard Video
format ur computer once again.. n install the driver..
Feb 14, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Graphics driver
Latest drivers for all motherboard components can be found on the sites of the respective components.
For example, if you want latest graphics drivers, search the internet for the Make and Model of your motherboard and say "graphics drivers".
For example, if the make and model of your motherboard is "Gigabyte 100X", then search google for "Gigabyte 100X graphics drivers".
Oct 19, 2007 | Microsoft Windows Vista Ultimate Edition
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
Aug 19, 2007 | Gigabyte GA-8I845GV-C (GBSA4LB)...
Gigabyte GA-8I865GVMK Motherboard Logo
277 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
steyr1
pankaj rautela
pankaj rautela
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
