Question about RIM BlackBerry Curve 8520 Smartphone
When ever i press a key on my blackberry curve it does not do anything, it only turns on when i put it to charge or when i take out the bettery and put it back on
Sometime when i have it on my pocket and i take it out i see that i pressed some keys but then i try to put my password and it doesn't let me type it
  • 580 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Posted on Oct 25, 2012
  • 50 Answers
SOURCE: CURVE 8330 will turn on (AFTER A FEW MIN) AND THATS ALL IT DOES
Dont give your cell phone to newbie to practice on, you can only trust experienced Techinicians at Dr. Cell Phone.
For more information on cell phone repair or BlackBerry Repair visit www.drcellphone.com
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: blackberry types wrong two letters on answer, trackpad, a etc.
Try Software. Most likely software problem, water damage would mess it up worse. Try googleing it, and useing blackberry support forums. On my old Windows Mobile phone, the ROM has many of those glitches. Your best bet would be a backup > Soft Reset > Hard Reset > Then check it. If problem persists, Do what i said above about the support forums, they will help you with software to reset keyboard
:) God Bless
Posted on Jul 13, 2009
SOURCE: the keys on my blackberry curve will not light up.
reformat
Posted on Aug 03, 2009
bahratt
  • 561 Answers
SOURCE: my blackberry keeps pressing keys by itself and
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 12, 2010
  • 19 Answers
SOURCE: blackberry curve 8900 key pad press y appear z,
adapt
Posted on Mar 26, 2010
Blackberry won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 02, 2012 | RIM BlackBerry Curve 8520 Smartphone
I need instructions on how to unlock this phone from verzion cmda not the one with a sim card
You must have blackberry curve 8520 unlock code for verizon network before you can unlock your blackberry. That code can be obtained from verizon or third party sites, both of them will take you some charge for a straight blackberry unlock code, but third party sites more cheaper and quick delivery times rather than network provider.
Jul 15, 2011 | RIM otion BlackBerry Curve 8520 Smartphone
I have a blackberry curve 9300. Last night the battery was at about 24% but when i woke up this morning it wouldn't turn on. It has been plugged in for hours and all I get is a picture of a bettery...
goodluck! Maybe a new charging cable or the battery or battery port in the phone is going bad.
May 25, 2017 | RIM BlackBerry Curve 8310 Smartphone
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
I need unlock code for my blackberry 8520 curve
How To Unlock a Blackberry Curve 8520 1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
Feb 12, 2010 | RIM BlackBerry Curve 8520 Smartphone
As I was updating the software on my BB Curve 8300 the screen on my computer said the BB had been disconnected and now all I have on my BB is a circle with a folder inside it with the number 507 beneath...
Hold down the ALT key, and press right-hand CAP key press the DELETE key aswell together which resets the blackberry . Still if you issue Open BlackBerry Desktop Manager and double-click the Application Loader icon. Use the application loader tool to Re install the BlackBerry Device Software.
Thank you
Nov 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a blackberry curve and when I turned it on after it being off and charging, a battery with a lightning bolt appears, but the phone will not turn on. Any ideas??
Battery power can be maximized by following these simple suggestions.
  • To delete a highlighted item, press the Delete key.
  • To select or clear a check box, press the Space key.
  • To view available values in a field, press the Alt key.
  • To switch applications:
    1. Hold the Alt key and press the Escape key.
    2. Continue to hold the Alt key and highlight an application.
    3. Release the Alt key.
  • Set the Auto On/Off option to turn off the BlackBerry smartphone at a time of day when you are not using it (such as at night), and turn on again at a time of day that you are ready to use it (such as in the morning just before you wake up). Battery power is saved by turning the power off at times when the BlackBerry smartphone is not being used. To set the Auto On/Off option on the BlackBerry smartphone, complete the following steps:
    1. On the Home screen, open Options.
    2. Select Auto On/Off.
    3. Specify the on and off times.
    If all this dosen't work please walk into the nearest service center to check you're blackberry Handheld battery is fine.
    Oct 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
    When i turn pearl on, battery with red line through it
    On my blackberry (Curve, aka 8830) that means the battery is almost dead. Have you tried charging it?
    Aug 17, 2009 | RIM BlackBerry Pearl 8100
    The charging icon is alway on:(
    take out the bettery but it out for 15 min then put in back on the PDA ....Regards
    Jun 24, 2009 | RIM BlackBerry Curve 8310 Smartphone
    My blackberry is completely frozen and i cant press anything
    You phone could just need a simple reset if the problem is based upon the software.
    To do that click the link below to download the Blackberry Desktop Manager and the Blackberry Device Software for your Curve and run the app loader to reset your device
    https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
    Jan 23, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
    RIM BlackBerry Curve 8520 Smartphone Logo
    37 people viewed this question
    Top RIM Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Longtime User
    Jason
    Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
