Question about KitchenAid KSM95ER Mixer
Ksm95 won't power on
Won't power on
    Problem Solver:
  • 9 Answers
Most have internal relays that can only be replaced by opening the unit. Unless you are experienced technician, I suggest a local repair or fix shop. Kitchen Aid will also repair the unit if you ship it back to their factory with return postage. If the warranty is out, the cost for repair, shipping, could exceed the cost of replacement. Good luck.
Posted on Oct 25, 2012
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
Head won't lock
It sounds like the latch, link & lever assembly need to be replaced, it does require taking apart the mixer, but is a fairly easy fix.
Here is a link to the replacement part: http://www.mendingshed.com/24452-2.html
And also here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
Page 15 will specifically talk about replaceing that assembly.
Jan 17, 2014 | KitchenAid KSM95 300 Watts Stand Mixer
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
Kitchenaid mixer on high all the time
I think that the mechanical speed control is stuck. Unless you are not afraid to take the mixer apart, you will need to take it toa shop or return it to the store for another one.
Dec 30, 2012 | KitchenAid KSM95 300 Watts Stand Mixer
My KitchenAid mixer won't turn on
Sounds like the carbon brushes under the black side caps or failing that a broken wire.
Dec 18, 2012 | KitchenAid Artisan Series 5 qt. Stand...
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
Dec 16, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Nov 05, 2012 | KitchenAid Food Mixers
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Beater won't turn, but motor is running.
Hi, Did you push the beater in so that it clicks. If all is good there, gear box maybe at fault or jammed. Take it to a service center for repair. If you are machanicly inclined (DIY) Take it apart and see why its not turning. Good luck.
Jun 04, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM95ER Mixer Logo
56 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
