New belt very adjusted, motor is stop, that i do?
    Master:
  • 444 Answers
Check if it possibally has a fuse that blew. If not the motor is probaly burnt out, Or all so check that your plug is good, Or that you didn,t kick off a breaker or fuse in your power box.
Posted on Oct 25, 2012
The T202 belt is not in the center
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Jan 21, 2013 | Horizon Academy Sports Fitness T202...
C2200 belt is slipping How to adjust??
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s)
May 18, 2010 | Nordic Track /proform Treadmill...
When weight is put on belt it stops. works fine by itself at all speeds
If you can stop the belt. You need to be aware that both running & drive belts can cause the same problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | Proform Sport 1000 Folding Treadmill...
How can you tighten the walking belt on a Image 15.R treadmill. Im pretty sure that its the belt you walk on that is slipping and not the one under the hood but I could be wrong. Any advice?
If you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | RTO Image 15.0R Treadmill Walking Belt
The belt is slipping when running on ithas been standing in cold conservatory
Mar 01, 2010 | Horizon Exercise & Fitness
The belt is slipping with each step
Mar 01, 2010 | Proform XP 590S TREADMILL Drive Motor
My belt is skipping on my Pro-Form 750
At the end of of the running belts in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Exercise & Fitness
I have a nordic track c2000. It has started a skipping/hiccoughing when I am on it. The belt is tight enough, so I feel pretty sure it is not that. I tightened it as much as possible
Feb 25, 2010 | NordicTrack Exercise & Fitness
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
