Question about Microwave Ovens
Fgmv174kfb dim display
Newly installed Frigidaire MW has display too dim to see with lights on in kitchen. does not change when unit runs or is idle (clock) . cannot find anything in instructions on changing brightness (like on daughters Whirlpool MW which is adjustable) . Any secret control settings that can be changed? Is this normal? the new Fridgidaire range has nice bright easy to read display. MW otherwise works ok. richard l in Houston 10-24-2012
  • Microwave Ovens Master
  • 9,047 Answers
The owner's manual (here) does not mention that as a feature, so I would assume the oven has a defect and would need to be returned to your dealer to be exchanged under warranty.
Posted on Oct 26, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Dim LED Lights
We can replace the VFD tube for you. The total cost for this repair is $71.06. For more information, our site is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Posted on Nov 28, 2007
SOURCE: Whirlpool GH5184XPQ 1100 Watts Microwave Oven Fan Won't stop running
Check for any cardboard on the side - that is not removed.  This also can cause problems :
- Kiran.
Posted on Oct 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: When new microwave is turned on, the lights in the kitchen dim.
Sounds like your microwave's outlet is on the same circuit with the lights.
High-current devices like microwave ovens should be on their own breaker if possible.
If the dimming is very slight, it may be okay.
If it's considerable, it may be a good idea to run a separate line to the microwave's outlet - especially if it starts blowing your breaker!
Posted on Feb 08, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM 1650 Microwave Night Light does not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
In your case, it may just be a shorted dimming diode, a black diode usually located between the light relay and the connector.
(Not to be mistaken for the tinier red-bodied diode on the other side of the relay that protects the relay coil).
If it is shorted, you will have bright lights in both the bright and dim settings.
In case you or someone you know has the tools and experience to desolder and solder small components, the replacement rectifier diode is not critical and can be any of these:
1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, NTE116, or NTE125 some of which are available form Radio Shack.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Frigidaire Mod: FGMV174KFB Door won't latch
Good Morning Friend,
I understand the door will not latch on your Frigidaire microwave, model# FGMV174KFB. Typically, this would not be a do it yourself repair, as you are working with your microwave, and there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the latch on your door with ease. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Microwave Ovens
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
Display very dim
Thats just judgemental, depeding on sentimnets you have for it...ask yourself a question: why would you buy a new MW if the one you have does the same as the new one you would probably buy?
Nov 28, 2013 | Frigidaire FMV145K Microwave Oven
Model # fgmv174kfb no power will not turn on
The problem is in the keypad control board or the smart board.
May 07, 2012 | Frigidaire FGMV174K Microwave Oven
My microwave wont heat up but runs normal
The make & model number would be helpful. There are alot of veriables that might cause this to occur. How long was the MW in use (the unit might have been to hot and the safety engaged) keeping the fan on to cool it down. There could be an issue with with one of the door interlock switches. Depending on the engineering, the control board could have had a hickup via a over current & shut down to protect itself. During the cut out was the cavity light on when the door was open. was the display blank. If you unplugged the unit waited a minute & then plugged it back in, did it operate again. It is not a good idea to open the control panel up, if your do not understand how to do basic electrical troubleshooting.
Mar 27, 2012 | Frigidaire Microwave Ovens
I need directions on how to set the clock. Can't find the manual
Select "User Pref" upper right corner of keypad, then select from menu "Clock" (item 5), then enter time, select "Start" - you are have just set the clock for Frigidaire FGMV174KFB
Nov 07, 2010 | Frigidaire FGMV174K Microwave Oven
Dim control panel unable to read
Removed the amber glass which obscures the display enough to remove the wiring from view. This also allows you to see the characters much more clearly. You now can see the inidvidual light elements.
It's not too bad, people don't even notice, but they do notice you can now tell the time and see what the oven is doing.
Nov 10, 2008 | Frigidaire Microwave Ovens
R-1751 display issue and the work light is on always
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Oct 17, 2008 | Sharp R-1750 Microwave Oven
Microwave Ovens Logo
244 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
