Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Suddenly my cook top stop working . all 4 elements dont work . but my oven works fine and time control works with all the lights . what could it be? please help !
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
SOURCE: Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Posted on Dec 10, 2008
  • 112 Answers
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
  • 35 Answers
SOURCE: Oven Element and Broil both do not heat
you should have 220v between the two terminals of the elements, either the switch is broken or a contact is burned or a feed wire is broken to the switch, check wire diagram and carefully analyze the system while it is "hot" ie... energized
Posted on Sep 17, 2009
Stove top stopped working but oven and warmer element work.
You have a defective breaker. Once you replace it the oven will get the correct voltage restored.
Aug 13, 2016 | Kitchen Ranges
How do i fix an oven that bakes unevenly
the cooking I can't help with, but the oven I can.
sounds to me like the bottom element or what controls it is not working. the reason the ones on top are cooking is that the top element is coming on and browning them on top after the heat has made the dow rise and cook.
so essentially everything is cooking from the top down. so when the temp drops its using the top element to heat with and thus browns the top rack.
check ur elements to make sure both work, if so, move on to the thermostat which I have to be the culprit many times.
Feb 26, 2015 | Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
103 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
