Question about Ctm Health & Beauty
CTM HS 120: battery did not hold charge as usual. Died with two lights showing, but extreme right red light flash continaully which I never saws before. es even when other lights are on.
What does right flashing light indicate?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
Could be low voltage indicator.
Posted on Nov 23, 2014
SOURCE: wont go forwards or backwards
are you sure its in gear. the nob on the moter should be towards the front of the machine! Hope this helps
Posted on Apr 07, 2009
SOURCE: 4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Posted on Jul 14, 2009
gewiz
  • 1263 Answers
SOURCE: Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Posted on Oct 01, 2009
  • 103 Answers
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Posted on Dec 16, 2009
  • 61 Answers
SOURCE: Shoprider- wheelchair will not move-Lights keep flashing
This usually occurs when either the battery charger is still plugged in when the button is pressed to turn on the wheelchair, or if the joystick has got 'Locked'. On the majority of electric wheelchairs you can lock the joystick control so that the wheelchair cannot be moved, for instance, it it was left outside a shop. You would need a manual for the controller from the manufacturer to tell you how to unlock it. You should be able to find this online somewhere. Most controllers on shopriders are made by Penny & Giles (P&G Drives Technology). Hope thats helpful to you...
Posted on Mar 19, 2010
Diagnostic red light flashing 9 times on CTM HS 360
hi Leslie, Sadly that is most likely a controller fault...
Please contact me if in the uk as i offer a free testing service...
Regards
Rob
May 02, 2016 | Ctm Health & Beauty
The self-diagnostic light is flashing 5 times for a brake fault.
CTM info on flashing 5 times is CHECK FREEWHEEL LEVER IS IN DRIVE,,check wiring .connections good luck
Apr 21, 2016 | Ctm HS 125 3 Wheel Power Scooter
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
www.gewizrepairs.co.uk
Mar 30, 2014 | CTM Homecare CTM HS-580 4-Wheel Power...
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
It never holds a charge, looks charged in the morning, but goes down to one red bar in an hour or two. Then all speed lights will flash with a yellow flashing light sometimes below them, looks like a...
Babble replace the batteries and check out my tip on charging your new batteries. if Medicare paid for your chair then they will cover most of the cost of new batteries contact the provider that sold you your chair and ask if they can change the battries for you Hope this helps
Mar 01, 2011 | Ctm HS-2800 Power Wheelchair
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
Nov 24, 2010 | Ctm HS-2800 Power Wheelchair
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
As the battery properly charged hs 2800, two LEDs flash yellow when I turn it on.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 12, 2010 | Ctm HS-2800 Power Wheelchair
CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Sep 04, 2009 | Ctm HS-2800 Power Wheelchair
Health & Beauty Logo
157 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Dan Apthorp
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
