Question about Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage
After turning height gage the display turn to 8888
Mitutoyo 18' height gage code no. 192-606. Yes I know its old. It has a 3 AA battery system. I really need a parts list, can' find one any where. Can you help me?
Thanks,
Kenny
Yes I have a parts list. send me a fax nuber and I can send you a copy. Bad news though a lot of the parts are discontinued.
Posted on Jan 10, 2009
  • JAmie Keene Jan 10, 2009
    Yes I have a parts list. send me a fax nuber and I can send you a copy. Bad news though a lot of the parts are discontinued. pcr1@rochester.rr.com
I have an 04 Alero. I just changed my battery and now my service vehicle soon light came on. I went to AutoZone and they said their scanner didn't read any codes. What should I do?
Do you know how to do electrical testing ? Have a volt meter ?
Malfunction Indicator Lamp (MIL) Always On
Battery positive voltage is supplied directly to the malfunction indicator lamp (MIL). The powertrain control module (PCM) turns the MIL ON by grounding the MIL control circuit.
This step determines if the condition is with the MIL control circuit or the PCM.
Did you perform the Diagnostic System Check-Engine Controls?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Engine Controls
  1. Turn OFF the ignition.
  2. Disconnect the PCM.
  3. Turn ON the ignition, with the engine OFF.
  4. Observe the MIL.
Is the MIL illuminated?
YES - Go to Step 3
NO - Go to Step 5
  1. Remove the instrument panel cluster (IPC). Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
  2. Test the MIL control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 6
NO - Go to Step 4
Replace the IPC. Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
Did you complete the replacement?
Go to Step 6
5
Replace the PCM. Refer to Powertrain Control Module Replacement .
Go to Step 6
6
  1. Turn the ignition OFF for 30 seconds.
  2. Start the engine.
Does the vehicle operate correctly without any MIL illumination, and without any stored DTCs?
System OK
Mar 16, 2016 | Cars & Trucks
How do I shut it off
Digital micrometers with LCD displays usually do not have a power on.off feature. Older units have an "on" button only that is used to turn them back on after a predetermined time-out or period if inactivity to conserve battery capacity but newer Mitutoyo mics cannot be turned off.
Feb 26, 2015 | Mitutoyo 317-351 Digital...
How do i make a hole place of origin
zero at the hole, otherwise you will have to add or subtract distances from the holes location.
Feb 19, 2015 | Mitutoyo Series 192 24" Height Gage
Varied reading being obtained cannot calibrate is the a recommended repair facitlity in Yorkshire England
Hello. There appears to be a facility in Hampshire, I do not know the limits of the services they offer. But I have attached the appropriate page link for you, click on the "services and support" tab or the "about us and contact" tab - I'm certain they will be able to assist you further. If this helps, please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.co.uk/Mit/mws.jsp?home
Apr 04, 2011 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
Reading vary cannot be calibrated
Hello. Here is the link to the height gage page(s) at Mitutoyo, Find the unit you have to verify model/serial number and then access their "contact us" option - they will be able to assist you. Hope this helps, if it does please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.com/ProductTypeResultForm.aspx?type=1262#
I have a mitutoyo dial depth gauge. How do I use and read this?
A dial depth gage should have a set of depth stems. they are in 1" increments. to change the stem, first using a scale, measure the depth of the hole you are checking. Find the stem that falls in that range. remove the cap on the top of the unit, pull the existing stem out and replace it with the stem you need to reach the bottom of the hole. replace the screw-on cap. Set the cross bar of the body on the face of the part. Gently turn the barrel until the stem touches the bottom. the barrel has a 1" range. The numbers represent .1". The lines between the numbers represent .025". One turn of the dial equals .025" Add the length of the stem, the number on the barrel, the number on the dial and the number diall. Example, If the hole measures between 3" and 4" i.e. (3-1/8")start by installing the 3 to 4" stem. Turn the barrel so it reads "0". place the cross bar of the body so it touches the face perpendicular to the hole. Gently turn the barrel of the unit until it stops at the bottom of the hole. Add 3" plus the number on the barrel (.1"), the number of graduations on the barrel, and the number on the dial (.023"). The reading is 3.123". If you know your decimal equivalents, you will know that the hole is .002" short of 3.125" (or 3-1/8" deep.
Feb 21, 2011 | Mitutoyo 0-6"X.001" DIAL TYPE MITUTOYO...
We have a Lucent partner 18-d phone system. Display is telling us to replace systembattery. We cannot locate this.
The "18-d" is the telephone set model. The Partner System control unit is where you will find the system battery. It is located in the Processor Module - usually 2 AA batteries.
Nov 19, 2009 | Lucent PARTNER18 Corded Phone
Fluke 8060AA digital multimeter
The fuse has nothing to do with the display.
The contacts of the LCD are probably oxidized because of its age. With the unit out of its care, carefully remove the LCD from its retaining mount. Use rubbing alcohol and a clean q-tip to clean the contacts of the LCD and the small "rubber-like" strips that contact both sides of the LCD. Also, remove the strips and clean the other side and the contact on the main circuit board. Then reassemble.
*Note, if you live in a cold climate, freezing of the LCD could also cause this problem. In that case you must purchase a replacement LCD from Fluke.
Oct 10, 2008 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
D200
what is the actual proablem?
Nov 17, 2007 | Nikon D200 Digital Camera with 18-200mm...
Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage Logo
549 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Glenn
Glenn
Dragan Manojlovic
Dragan Manojlovic
Level 1 Expert
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
