Dell dimension 8400 desktop shuts off by itself and power light blinks amber
  • 5,660 Answers
Which is a direct indication of a bad Power Supply,
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm#wp1053720
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147665&CatId=1078
http://support.dell.com/support/edocs/systems/dim8400/SM/parts.htm#wp1058213
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Also clean the inside of the computer out with a can, or two of compressed air for computers. You may find a soft small brush, and Q-tips will help. ('Stir' the Gunk around to 'break the crust', then the compressed air can remove it better)
Power unplugged from computer, ('Natch), and Anti-Static Precautions -> FOLLOWED.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Oct 25, 2012
  • 1 more comment
  • joecoolvette
    joecoolvette Oct 25, 2012
    Thank you for the rating Jay!
  • jay266
    jay266 Feb 04, 2013
    Tthanks for your help. And the great links
  • joecoolvette
    joecoolvette Feb 04, 2013
    You're welcome Anytime!
tom19511
  • 1601 Answers
SOURCE: Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Posted on Jan 13, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
Hello everyone, check your cpu - I've just had one of these in for repair and the cpu was faulty - removing the ATX 4way 12v lead let the pc start rather then detecting a short and shutting the psu down. Changing the cpu cured the fault.
Thanks
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Posted on Jun 28, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
Dell 8400 a c diagnostic lights on amber
Henry,
The Amber A and C signifies a failure to post. Computers Post BIOS to Processor, then RAM, then back to Processor before initializing the other devices. Try reseating the RAM or replacing it before you go further.
If you have upgraded the devices within the PC recently, you should consider that you should not be running anything less than a 350W power supply.
I hope this helps.
Oct 28, 2012 | Dell Dimension 8400 PC Desktop
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
http://shop.ebay.com/i.html?_kw=T7787&_kw=DELL&_kw=Motherboard
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
My dell dimension 8400 canot boot up at all and the Diagnostic Lights not light oso..so wat i can do?
The POWER and DIAG LEDs can give you information. If no DIAG LED look at the POWER LED
Flashing amber, most likely the power supply
Solid Amber, motherboard or item plugged into the motherboard (Expansion card, external connection etc.)
Apr 17, 2010 | Dell Dimension 8400 PC Desktop
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Dell Dimension 8400 power supply
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Woes with Dell
Jan 13, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
