Question about Grohe Home
Grohe 2700 7000 shower head leaks at wall
2-year-old installation. Water running out between wall and mounting fixture. Not sure how to remove fixture from wall to check what's leaking.
2 Suggested Answers
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Hansgrohe shower head water leaking out of connector
Is it a Grohe or Hansgrohe shower head? If it is a Hansgrohe shower head the first thing to check is if the self sealing filter gasket is installed at the connection to the shower arm. Hansgrohe shower heads have a black self sealing filter gasket in the head that some people remove assuming it is a flow restriction device. It is only a filter and does not restrict flow unless clogged with debris. Next make sure the flow restriction device below the filter gasket is still installed. On some models removing the flow restrictor will cause water to be expressed from the air injection ports near the pivot ball. Feel free to contact me at Hansgrohe. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough
Aug 20, 2012 | Grohe Home
Sliding holder for hand held shower head slips on mounting rod - loose
The locking screw, if that's what it is, may have stripped threads.
Jun 07, 2017 | Grohe Home
I want to replace an old single handle builders no-name shower, about 15 years old with a gromhix 34436 unit. My shower is tile. What steps should be expected? Is this practical?
Usually a shower stall will boarder a wall where you can access the fixture by cutting a hole in a boaring wall to get at it. If it boarders a closet or someplace thats not conspicuos, there may already be an access hole. Once you have access to the old fixture, you can remove it and, as long as the new fixture is the same size or larger, it shouldn't be that much of a problem. You may have to make the hole in the tile larger but, you should be able to do that with a 90 deg. grinder. Usually most, if not all, shower valve(single) have pretty much the same configuration. If your pies look to be in good condition, you should be able to work with piecing in the new fixture. If you cannot access the fixture from the back sie, well, thats a different story and, alo of work in redoing tile you probably won't be able to match and, a little bit of drywall work but, if you only cut the hole a sbig a you need it,you use some sort of fired decorative tile to cover the repairs spot. It's up to you.
Jun 06, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Jul 08, 2009 | Water Pik Wall Mount Shower Head
I have agrohe shower fixture with poor pressure
If the shower head is clogged (even if it it is not I would still do this)
remove the head and soak in coke (yes, it works), CLR, vinegar or bleach and see if you can dissolve the debris. If that is not the culprit, check to see if there is access to a shut-off valve behind or below the shower. It will be inside of the wall and is only acessable through a hole in the wall.
If that is not the case, it is now time to consider replacing the shower body. This is an involved job but something very doable by a competent homeowner.
Hope this helped.
Apr 15, 2009 | Grohe Home
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Home Logo
56 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
