Question about Sewing Machines
Thread tension problem
Can't balance the tension of the three thread spools----help!
  • Sewing Machines Master
  • 1,564 Answers
Got a serger huh? First put 3 different colors on the spool holders. Then play with tensions so you understand which thread does what.
It's trial and error. Good luck.
Posted on Nov 06, 2012
  • 1 more comment
  • lbtaylor44
    lbtaylor44 Nov 08, 2012
    No solution but thanks anyway.
  • sylviaivie Nov 08, 2012
    Sergers take a lot of time learning how to use. There is no quick answer. You have to be willing to go through the trial and error process. Otherwise just sell the serger and move on.
  • lbtaylor44
    Yes, thank you!
3 Suggested Answers
Mimito7
  • 128 Answers
SOURCE: cannot get tension balance correct
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
Posted on Apr 20, 2009
SOURCE: Can't balance top/bottom thread tension-model
I disassembled the top thread tension controller consisting of 12-13 pieces, including 2 springs. Since they all fell out on the table I spent about 2 hours learning the proper stacking order on the central shaft.
With a combination of reasoning based on each unique piece shape and trial and error I put it back together, adjusted top and bottom tensions according to the instruction booklet for the machine, tested some stitching, made final adjustments and all worked well.
I don't know what was changed in the process but it worked.
Don
Posted on Sep 04, 2009
Sewing machine tension
the tension dial may need to be replaced, it would be a good
idea to have the machine checked
Feb 06, 2013 | Sewing Machines
Upper tension when sewing fleece
This seems silly to ask but are you remembering to put down the foot? Try re-threading the upper thread with the foot raised... then try again. Make sure that your thread spool isn't catching the thread in that little thread keeper slot. Also make sure it isn't spooling in such a way that it wraps extra lines of thread around the spool pin. Also make sure you are using a Needle designed for sewing fleece.
Jul 16, 2012 | Sewing Machines
Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
Top thread janome tension
it's possible that the spring got damaged & it needs to be check at a sewing machine shop
Mar 19, 2012 | Janome Sewing Machines
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
Jan 27, 2012 | Bernina Artista 180
My top thread frays and then breaks while I am quilting with my 1600p dbx.
change to a new needle
check to make sure thread has no knots or even change the thread spool
check the top thread tension it sound like it's to tight
check the needle plate for burrs
check around the tension knob for loose pieces of thread or lint
use a can of air that you'd use on a computer keyboard on the tension knob & if you don't have the can of air use unwaxed dental floss but make sure to write down the setting it was on before cleaning.
& also under the needle plate area in case there is loose threads or lint & also the bobbin area
Aug 11, 2011 | Janome 1600P-DB Mechanical Sewing Machine
The top thread continues to break once I begin sewing. I have done all the recommended changes (tension controls, etc.) Everything is threaded correctly. It appears the top thread or the bobbin thread...
I know you've said you have checked the tensions but that usually is the problem. When you pull on the top thread after it goes through the tension but before you thread it through the needle is there some tension but not so much that it breaks when you gently pull on it? It will be a bit harder to pull it at the point after it goes through the needle but it should have a bit of give there too without breaking.
Also check the bobbin again. Take it out of the machine and examine how the thread is wound around the bobbin. Is it all criss crossed or is it fairly evenly wound? Is it in the right direction and through the tension slot? Now dangle it by the thread while in the bobbin case. It should not just reel out to the floor but should slip a bit with some tension and hang there. A slight **** of the wrist should cause it to release a bit more thread and drop a bit more to the floor. It should allow slip but it shouldn't just reel out fast.
When you reinsert the bobbin case into the machine you should feel/hear a slight click as it catches into place.
Also check the needle though that usually isn't what causes this kind of problem.
The thread will break when it has no 'give'. Either the tensions aren't quite right or it is catching somewhere along the way through the various guides where you thread it. Oh and make sure the spool itself is freely turning on the spindle! Sometimes it is because of catching at that point and simply turning the spool upside down so it can't catch will solve the problem ! :)
May 24, 2011 | Simplicity Pioneer II SA200 Mechanical...
I want to use a metallic thread for decorative sewing but the thread keeps breaking , can anyone help. I am new to the machine & embroidery thread
Three things to check:
1.You need to use a needle specifically made for metallic thread. I believe the eye of the needle is square and the thread will pass through it easier, and will not be shredded which can be a cause of breaking.
2. Be sure to check your tension to make sure it is not too tight on the top. Test your stitches, checking both top and bottom tension.
3. The thread should come off the spool straight, not twisting. The thread cone should be standing up straight and the spool should twirl to release the thread. If the spool is not moving and the thread unwinds from the stationary spool, then the thread is twisting and that can cause the breakage as well.
Nov 27, 2010 | Janome Memory Craft 9000 Computerized...
How do i thread my needle with the singer handy stitch?
  1. Loosen needle screw & insert needle with shank's flat side facing front of machine. Push needle in all the way, then tighten screw to hold needle in place.
  2. Install a fully wound bobbin by loosening bobbin nut & placing bobbin on top. Re-attach bobbin nut & tighten. If standard thread spool will be used, then attach spool pin to bobbin shaft & place thread spool onto shaft. Attach white spool cap on end of thread spool, then tighten. Bobbin/spool should unwind facing forward toward needle.
  3. Bring end of thread through thread guides & over tension control. Pass end of thread through needle eye, from back to front, & pull it out about two inches.
  4. A spring pushes pressor foot onto fabric that is being sewn, so lift pressor foot & place fabric underneath.
  5. Turn large handwheel on side of machine (handwheel can be turned in either direction) to raise needle arm to its highest position.
  6. Holding the Handy Stitch in place with your right hand, press on power switch & begin sewing. Guide fabric (being sewn) with your left hand.
  7. To end this sewing session, turn off power. Turn handwheel to raise needle to its highest position. Carefully pull out about three inches of thread through needle & snip, then lift pressor foot to remove fabric. Turn fabric over & loop needle threader through last stitch. Place end of thread from underside through eye of needle threader, & pull to loop through. Pull to tighten and snip end of thread.
Nov 11, 2010 | As Seen On TV Handy Stitch Mechanical...
Problem with spool Thread, please suggest a solution!
This is a tension problem.
In addition to the top thread having a tension adjustment there is the facility to adjust the tension of the bottom(bobbin) thread.
Both these tensions need to be correct to get a balanced stitch and to stop the loose threads underneath the cloth.
It is almost impossible to explain how to adjust the bottom tension you need to be shown.
Somewhere in your manual it should explain how to do this.
Jan 29, 2008 | Janome Mini Compact
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
