Question about Frigidaire Dryers
I have a front load frigidaire affinity dryer that keeps saying the door is open when its not. my rmmt said it read error 66 b4 i cld look at it. what does error 66 mean or keeps saying door is open?
Model# fase7073lao front load
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
SOURCE: Error code LOC on frigidaire front load dryer
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Posted on Jun 07, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
How to replace heating element on frigidaire fase7073lao dryer?
Takes Frigidaire (OEM) Part #134792700
http://www.ebay.com/itm/134792700-NEW-Genuine-Electrolux-Frigidaire-Kenmore-Dryer-Heating-Element-OEM-/181461935813?pt=LH_DefaultDomain_0&hash=item2a3ff966c5
~ $87 w/free shipping
Here's more pix on YouTube. Get your screwdriver out and go at it. You'll never learn any younger. Write down and/or label where EACH wire goes as you disassemble. Just remember SAFETY FIRST. NO POWER while you're working on this ! UNPLUG is enough, there is no residual voltage on a dryer. Best help may be on YouTube. ask for (type in) Frigidaire Electric Dryer repair. There are several videos, one of which should serve to give you courage and a starting point if you've never done it before.
Jul 20, 2014 | Dryers
I have a frigidaire Front load dryer model number FASE7073LAO. The dryer stopped working gave a code for the heater element. We took that to the local parts guy and the whole unit tested fine. So, we...
Hello Paul
Can you check this following parts:
Make sure the dryer is plugged in securely
Check for a blown fuse or tripped circuit breaker
Test the power outlet for voltage
Inspect the electrical cord for damage
Eliminate use of an extension cord, if any is being used
Check the outlet voltage
Test the door switch
Test the start switch
Test the safety fuse
Test the thermostats
Test the timer motor
Test the motor
Best Regards
Neciforo Llanto
Sep 30, 2013 | Dryers
I have been given a Whirlpool AWM 312 by friends moving overseas and don't know how to operate it and would like to get a manual. My main problem is what drawer (front the left facing the machine) do I...
The manuals for most Whirlpool appliances are available here: http://www.whirlpool.com/custserv/index.jsp . Look for the full model number under the lid on the rim of the washer. AWM 312 is not a complete model number. Next is the washer a top loading or front loading machine? This is actually indicated in the model number - most Whirlpool models start WFW (front-load) or WTW (top-load). The exception is the compact washers (LCE4332PQ is the current model).
For the front-loading washers, the detergent goes into the largest compartment (usually the left-most part of the drawer). Top-loading washers that have a detergent compartment usually have it positioned at the top center back of the tub. Use HE detergent for high efficiency washers and do not use more detergent than recommended (using less is okay).
I hope this helps.
Mar 03, 2011 | Washing Machines
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Dryers Logo
69 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
