Question about Toshiba TN55X81 55" Rear Projection Television
Troubleshoot flashing light on toshiba projection tv
  • 87 Answers
SOURCE: toshiba projection tv
Unplug the TV from the outlet for about 30 seconds. This will reset the microprocessor. Re apply AC and power on the TV. If your lucky the set will come on and play. If not, the red light will start blinking again indicating shutdown. There are many reasons for the set to go into shutdown, but one of the most common cause is failure of the convergence output IC`s. If your TV is in shutdown, you will need to find a qualified technician for proper diagnosis and repair.
Posted on Nov 25, 2007
ctf1800
  • 4402 Answers
SOURCE: toshiba power light
i would look at the front panel switch assym. for loose connection (ground)
Posted on Jan 14, 2008
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
Posted on Jan 31, 2008
SOURCE: i have a toshiba projecter
Same on mine, been trying to find soulution for couple months now, appears one of the boards as failed , or a simple fuse inside, or bad connections, either way seems like a repair man needed for me, good look, : )
Posted on Jun 15, 2008
SOURCE: T.V. will shut itself off, power light flashes
my toshiba tv shuts itself off after about an hour or so
Posted on Feb 25, 2009
56 in toshiba rear projection tv. When u turn it on the green light comes on and a yellow light flashes 15times followed by a click sound. No picture. What does this mean?
Try going to www.toshiba.com to research your problem and what the 15 flashes of the yellow light means. Try unplugging your TV from the wall for about 30 seconds and then plug it back in. This will re-boot your TV (like re-booting your computer). If still no picture, if could be your bulb, motherboard or color wheel.
Mar 01, 2015 | Toshiba Televison & Video
When i turn on the my toshiba theater view tv all that happens is the of/on idicater light just flashes
We recommend you remove the "Digital In" cable connection from the rear of the TV and turn it back on. If the problem persists, we recommend having the TV evaluated by an authorized service center using the below link.
www.panasonic.com/repair
If the TV turns on then we recommend having the Toshiba Home Theater evaluated. Welcome to Panasonic Online Repair
Mar 26, 2014 | Panasonic PT-47WX53 47" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Jan 18, 2009 | Toshiba TN55V71 55" Rear Projection...
BLINKING POWER LIGHT AND TV DOES NOT POWER ON
I have a toshiba 61 inch projection tv the power light flashes with no picture any easy fixes?
Jun 24, 2008 | Toshiba TP61G90 61" Rear Projection...
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Toshiba TN55X81 55" Rear Projection Television Logo
13 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
