Question about Viking Ovens
Viking double oven fault (f08)?
New just installed wont start fault F08
5 Suggested Answers
  • 832 Answers
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
Posted on Sep 26, 2009
  • 1314 Answers
SOURCE: installing a new frigidaire double oven
there should be some screw holes along the sides installation instructions should have come with the unit but if they did not can get them here http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLEB27T9DC&User=&Search=Search
Posted on Feb 13, 2008
SOURCE: we have a westinghouse wall
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Posted on Jul 21, 2011
ginko
  • 19396 Answers
SOURCE: oven wont start
I understood that the oven does not heat.
If this is a gas oven start checking from igniter and coils. With electric oven check the thermostat.
If the appliance is completely dead (no power at all), start checking from power cord, progress to relay board (if present in this model), then test electronic control or switches.
Regards.
Ginko
Posted on Dec 04, 2011
How do I fix error code f08 on a zanussi zpb 120 built in oven
Fo8 is heater fault. Check element first
Nov 17, 2014 | Ovens
I have a Viking Oven and the code F o8 has shown up. What does that mean?
Hall effect sensor in cooling fan issue. Shut down and power up again . Or call tech assist at 888/845-4641. Hope this helps
Oct 20, 2014 | Viking Ovens
Fault code Close Door (__M) Keeps coming up and oven wont start
door switch on the right side (looking at the oven) is broken, part is about 2 to 3$, unscrew 2 screws and that's it
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Light is flashing reading Err 08 on electric oven model EW93 cuts main oven off?? why is this
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Mar 18, 2011 | Hotpoint Ovens
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Jan 23, 2011 | Ovens
Microwave wont heat
in 99% of cases the fault is the magnatron a very expensive part if the unit is more than 5 yrs old bin it and buy a new one
i hope this helps
take care
Dec 28, 2010 | Ovens
ERROR MESSAGE F 08 SHOWING ON WHIRLPOOL OVEN AK2456/1X
Jul 17, 2010 | Whirlpool AKZ159IX Oven
TOC
hi there if your toc is at fault you will have no oven function at all ie. fan, light, and timer display. i would first check your timer is not set to auto and is also got the time set, failing that your thermostat may be at fault.
May 22, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
504 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
