A8TZNU42 IDE Controller - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
Http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3317
Chipset Driver
It's for Windows 7 32-bit (x86) and Windows 7 64-bit (x64)
It refers to the Motherboard chipset.
It's an Intel HM55 motherboard chipset.
After you click on - Chipset Driver or Download, (Either one), a small window will come up on the right -
Opening Chipset_Intel_9.1.1.1024_W7x86W7x64_A.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
If not click on the small circle to the left of Save File.
Then click on OK at the bottom of the window.
A small download window will come up on the left.
Allow the file to fully download, then DOUBLE-click on it.
Follow the easy instructions to Install.
(Or post what you see in a Comment, and I'll guide you)
Regards,
joecoolvette
Posted on Oct 25, 2012
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
How do i change my sata controller to use ide?
Buy an IDE controller. Then install it.
OR
Buy a SATA hard drive and install it. SATA drives are faster. If you need to get data from your IDE drive to a new SATA drive, try using a IDE slave cable. These connect an IDE drive to one of your USB ports and allows you to use the drive just like an external hard drive or USB thumb drive. Pretty cool stuff. Have fun.
Oct 17, 2009 | Gateway DX4720-03 PC Desktop
Is there a way to repair a blown IDE controller in a Dell Dimension 8300.
Basically.....no, but you can add a PCI IDE controller card fairly cheap.
Aug 08, 2009 | Dell (W2562) Motherboard
How do I make my Acer E661GXM mobo read an IDE primary HDD and a SATA secondary HDD?
I didnt got exactly what ya want ...but I have some idea...
probably it says something like ( at identification on boot ) primary ide controller.....cd/dvd...... secondary ..ide ...hdd...... sata controller hdd....
this is not an issue of which one is primary ans so ....cause those are 2 completely different bus-es ...and the only way to make your ide hdd be read like primary ...its to change the plug with the one from the cd /dvd..drive ..
the rest doesnt matter cause it s a different controller...
Apr 11, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
IDE Problem (I Think)
Depends what kind of motherboard is. You may want to check with a different IDE ribbon cable. Make sure that the IDE controller is ENABLED within BIOS. Set the HDD as Master - see those jumpers next to the power and data connectors. Try with another (IDE) HDD and see if the controller is working. Don't asume the 1st HDD is working OK, you never know ...it may be broken now ...
Jan 09, 2009 | Computers & Internet
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
Driver for rtl 8139D
maybe you got the wrong version of your driver, realtek got an A&B device driver..
Feb 15, 2008 | Computers & Internet
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Printer Driver and Manual for a Canon MultiPass C3000
yedya gandichya driver cd sambhalta yet nahi tar printer kashala gandit ghalayla ghetlas
Jan 03, 2007 | Canon MultiPASS C3000 All-In-One InkJet...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
