Question about Gateway Computers & Internet
My laptop will hang up at loading your personal settins
When in turn on my laptop it hangs up at loading your personal settings, what can i do?
  • Gateway Master
  • 27,725 Answers
Laptop hang issues can be a frustrating issue for the user and a tedious problem for a technician.
The variety of causes for this event are staggering, but many can be diagnosed in a few simple steps.
Peripheral Issues
USB drives, inserted before boot, will cause a hang.
Remove all such devices and media (such as CDs and floppy disks) before booting your laptop.
Software Causes
Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help
you check for software causes for a hanging laptop.
By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance.
Perform a check disk by right-clicking on your "C Drive" found in "My Computer."
At the "Properties" link, press the "Tools" tab to schedule error checking.
Reboot your laptop and let it perform this check.
Hardware Causes
Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it.
Do not touch its gold contact points, as this may damage the memory.
Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk.
If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU.
Boot with the battery removed to verify that there is not an issue with power conflicts.
Final Considerations
Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes.
Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data.
This process requires your original Windows disks but is often quite useful.
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Posted on Oct 25, 2012
5 Suggested Answers
SOURCE: laptop acer travelmate 290 hanging
Is your battery 0k? it may be faulty. pull it out and see if you have the same problem with NO battery installed.
Posted on Jul 05, 2009
SOURCE: my acer travelmate 2500 hangs on post.
Please format your laptop.Install all the drivers properly
Posted on Jul 14, 2009
  • 674 Answers
SOURCE: my laptop hangs when i insert usb flash disk
1) Scan your system and USB device using good antivirus program.
2) Update device drivers.
3) Run Reginout scan.
Thanks
Posted on Aug 02, 2011
  • 674 Answers
SOURCE: My Laptop hangs during shutdown
Speed up your computer by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Wespro n720 hanging at loading os image how to solve this problem
You don't state the OS but usually it is a damaged system file.
On XP you can try this: Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It`ll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows. Now you can reset your account password from "Control Panel -> User Accounts". On Win 7 or Vista: Ctrl+Alt+Delete won`t work, you have to use some windows password recovery software. I recommend Windows Password Reset Deluxe
Read more: How to reset wespro n720 mini laptop? - My wespro n720 is start but hang all feature is not working :: Ask Me Fast at
How to reset wespro n720 mini laptop My wespro n720 is start but hang all...
Mar 21, 2013 | Sylvania Computers & Internet
My neo BASIC5100N "hangs" all the time
Depending on the version of windows that is on that machine you may need to update the drivers. You also could have an issue with the BIOS being an older version. Lastly you should check the power saving settings.
May 05, 2017 | Computers & Internet
Window instolation bootig files for hanging
Refix your RAM also check your hardisk is properly detected in bios .
Load optimal defaults settings in bios.
Aslo try with other bootable disk some times disk corruptation create this problem.
Jul 23, 2009 | Intel Motherboard
My acer travelmate 2500 hangs on post.
Jul 14, 2009 | Computers & Internet
Gateway laptop hang issue
Check the Windows Page File to determine whether it's system managed or manually set. The recommended settings is twice the amount of RAM installed in the machine. If set too low the system will hang often, especially when running memory hungry apps.
I would also suggest checking screensaver and power management options in the control panel.
If those don't work, close any unused applications which run at startup (Start, Run, MSCONFIG). Another possible solution could be updating your display driver.
Nov 06, 2008 | Gateway Computers & Internet
My ibm thinkpod 2647 always hang's up
It could be that the hard drive crashed. It should be looked at to see if that is the case.
Jun 10, 2008 | IBM ThinkPad T20 2647 Notebook
Sudden switch offf....................
Hi. 1st u go urs mobile setting and restore ur fectory setting its code is 00000.
Mar 06, 2008 | Motorola Mobility ROKR E6 Smartphone
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
