Question about Sony Playstation 3 (PS3) Console
LG RZ32LZ55 HDMI connection to PS3
I have an LG RZ32LZ55 TV and all the sites I have checked say it is HD Ready. Bought a PS3 today and a DVI to HDMI connection lead. When I switch on the PS3 it says HD connection detected. Graphics and picture on Blu Ray poor so went to settings to switch to HDMI - does not give option to connect automatically and if I choose to change to HDMI the screen goes blank for 30 seconds then goes back to prev menu. Any suggestions?
  • 18 Answers
SOURCE: Games run on hdmi, but not Blu-ray movies
You most likely have the updated drivers. You may have to go and change a setting. I found an answer on the PS3 website that may be of some use to you. I hope this helps you: http://boardsus.playstation.com/playstation/board/message?board.id=ps3&message.id=1662191 From the site: "go to bd/dvd setting and set the "108024hz" option off"
Posted on Aug 19, 2007
SOURCE: NO SURROUND SOUND WHEN PLAYING BLU-RAY
i had the same prob. Changing the ps3 audio settings from linar to bit rate did the job 4 me. I have a samsung dvd surround sound in a box package
Posted on May 06, 2008
bubulica2000
  • 55 Answers
SOURCE: Blu-Ray sound
go to Sound settings and select audio output to Optical.
Posted on Sep 05, 2008
  • 76 Answers
SOURCE: Just played a blu ray film, and it looks a little
Try using the regular A/V cable, its not going to be in HD quality but it might clear the washed out view, and you might get a better picture even tho not in high definition
Posted on Apr 14, 2010
Testimonial: "thanks for that I'll give it a go. He's hoping."
  • 85 Answers
SOURCE: My playstation 3 slim used to play blu-ray
double check display settings then the first open under there to see what it is set at maybe it defaulted back to 480 instead of hdmi 1080. Also try doing a lens cleaning from the disc that are brushless kmart sells them, and walmart but only online for wal mart this can drastically improve if its just a dirty lens doing it.
Posted on Apr 29, 2010
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
HOW DO I CONNECT A SKY HD BOX TO MY HD READY TV IF THERE IS NO HDMI CONNECTION ON THE TV ?
Use the SCART, it has Component Video connections that are capable of carrying HD signal at high quality.
May 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
What am supposed to do if my t dosen't have HDMI
Either HDMI to DVI adapter cable if TV has DVI in. Or component video cable (Green,Blue,Red jacks, plus White,Red for audio. Both will do HD.
May 01, 2010 | Vizio L30WGU 30 in. HD-Ready LCD...
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Compatibility ps3 lg rz32lz50 tv
Sounds like your DVI converter. DVI provides picture only, no sound. If your TV has an digital optical input socket, it's best to connect PS3 to TV using this, then digital stereo sound should be yours..
Sep 06, 2008 | LG RZ32LZ50 32 in. LCD Television
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Blu-Ray
Talk with salesman of each piece of equipment after consulting
owners manual for each unit..............................T.
May not be possible.....
Nov 20, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
113 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
