My 21 inch flat tv does'nt have volume or audio output i suspected audio ic was the problem can you give me best way to fix it parts tda1030 was not available in the narket can you gave me parts r
Replacements for tda1030
SOURCE: No Audio on 32 Inch LCD Flat Screen
If there's no sound at all, switching channels or not, then you may want to check this out:
http://bobbykolev.blogspot.com/2007/11/insignia-ns-lcd32-32-tv-power-sound.html
Posted on Nov 18, 2007
SOURCE: Half part is display
replace ic
Posted on Sep 29, 2008
  • 400 Answers
SOURCE: I HAVE 21 INCH LG FLATRON TV CHANNELS CHANGE
It is possible that there is other equipment which uses a similar frequency, this can be a cordless phone or a gate remote or other device capable of transmitting frequency
Posted on Mar 09, 2009
  • 814 Answers
SOURCE: Insignia 26 inch Flat Panel Internal Speakers Stop working
You need to test the unit on a external sound source, to see if the audio amplifier is working correctly. By checking it on another source you can determine if the sound amplifier system is failing or you have had some problem with you speakers. Once you determine the problem. If it is the speakers, you can replace them with new ones. However if it is the audio amplifier section failing you will have to take it to a service center where they have all the service information to do the repairs.If the unit is still under warranty, have it serviced by Insignia. You can reach their customer support with this telephone number !-877-467-4289. Give them the model number of your television and the problems you are having with it. The should be able to tell you how to have it serviced. You can also check out their website for customer support at www.insignia-products.com. If the unit is out of warranty, you must have someone help, you troubleshoot the problem and try buying parts for the repair. You can call this number for insignia parts. 1-888-237-8289. You can also search the Best Buy website for parts on these units. The website is www.bestbuy.com. Go to the parts search section and put in the brand name of you television and put in the model number. The search engine will bring up a parts list with prices. I hope this information has helped you with your problem. You should also be aware that Best Buy has had a recall of some these model units. Check my tips and hints postings for more information.
Posted on May 22, 2009
dave1645
  • 834 Answers
SOURCE: volume on Insignia 42 inch flat screen went out suddenly
you need the mainboard replaced
Posted on Sep 18, 2009
Humming sound coming from my 52 inch Samsung tv.
Check and replace damaged component/s at its audio output stage circuit. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Audio output IC is the most probable part to to this fault.
Dec 01, 2015 | Samsung Televison & Video
Volume go down automatic
The other "solution" is wrong.
the most common reason:
Jan 08, 2013 | Emerson LC320EMXF 32 in. LCD TV
Zenith B25A76R CRT TV howling sound from speakers
It sounds that there is some solder problems in the audio output section circuit. Loose solder terminals can poise this type of problem. Check it first. Re-solder all the suspected solder terminals by applying a little more solder. If this do not help you, just do as your suspect ion. Replace all the electrolytic capacitors at the audio output section circuit. IC too should be suspected. Check the seating or IC with its heat sink for tightness. If it is loose, the IC will overheat with time, the the fault you report here can occur. Check all of this. Good Luck.
Nov 24, 2012 | Zenith B25A76R 25" TV
Sony tv 21 inch horizontal output transistor failing frequently
• Power Supply B+ is higher than normal
• Partially shorted Flyback Transformer
• Bad Deflection Yoke
• Too much oscillation on the Jungle IC
• Bad capacitors around the horizontal output transistor
Sep 27, 2012 | Jwin JV-TV9090 21 inch TV
TV Picture reduces to a narrow horizontal bar
The vertical sweep output section circuit to your TV has the fault. Might be an IC failure, or with some loose solder points at the solder terminals to this IC. As it will be very difficult to detect the exact dry-solder point, it will be best to resolder all the suspected solder terminals to this vertical output section, by applying a little more solder to each terminals, without making any solder bridge short in between adjacent solder terminals.
Jul 30, 2012 | Quasar SP-2722 27" TV
My volume on my Toshiba led 3d tv is very low
Hello
Connect an other speaker, and check. If the external speaker also have low sound output, check the audio output section. Electrolytic capacitors and IC in that section can be suspected.
Mar 05, 2012 | Toshiba Televison & Video
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
The speakers are not working. if i turn up the volume, I can hear static noise, but do not get any sound. tv speakers are on. I played around with the audio settinds and all the different hdmi ports,...
Hello
There are two possibilites for this fault. The first one is, damaged speaker voice coil and the second one is damaged audio output IC. To confirm it you have to open your TV. Speakers can be checked without removing them from the cabin fittings. Check them with the helap of a multimeter; set in OHms range. You can alos check it with a standard torch cell also. Connect the two terminals of the torch cell to the two terminals of the speaker [intermittantly, not constantly]; will produce a 'thumb' sound; if the speaker is good.
Connect the 'audio out socket' of the tv, with any other audio equipment, and listen whether there is sound form the external audio equipment, like amplifier or so. If there is sound from the external audio equipment, and no sound from the internal speaker of the TV, and the speaker is good, surely the 'audio output IC' of the TV is damged and should be replaced. OK.
May 13, 2011 | Vizio M550NV 55 in LCD HDTV
The volume suddenly went out on our tv. you can hear static noise but no talking we havent had it but a few months ..
Hello
Either your TVs speakers or its output IC may have damaged. To confirm it, just up the volume of your tV, and try to hear the sound if any. If it feels like dostorted or very low-hard to hear, the speakers must be suspected. If there is no sound signal at all, output IC should be damaged. To confirm whether the sound detecting section is Ok, just connect your TVs audio output sockets at the rear of your TV with an amplifier or so, and rise the amplifier voluem, to get sound through it. If you get sound in this way, make sure that the above daid two items. Fist check the speaker, by connecting an external speaker in place and listen to it. If it also doesn't get the result, surely the output IC of your TV has damaged, and should be replaced with same type and number. OK.
Feb 27, 2011 | LG 37LG30 37 in. LCD HDTV
21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Oct 22, 2008 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
