Question about Dell Inspiron 15R Laptop Computer (Intel CORE I5 GB4GB) (dndor34b) PC Notebook
Static coming from speakers
Even when not listening to a video or music, static comes out from the speakers.
5 Suggested Answers
ice48507
  • 28 Answers
SOURCE: Static coming from my DELL AS500 speakers
It's the jack on the back of the PC or sound card. Sounds like some solder is loose on the jack.
The cheapest solution would likely be to just replace the sound card, if your comfortable installing them. It's really quick and pretty hard to mess up.
If it's "onboard" sound, meaning the audio jacks are built right into the mother board, you'd likely need to just replace it with a pci based sound card.
Posted on Dec 06, 2008
sys_admin
  • 829 Answers
SOURCE: static noise coming out of speakers
What sort of computer do you have? Is it a laptop or desktop? Many laptops have this problem and it is quite widespread in laptops. The crackling or humming noise could be a result of interference from the mains power signal.
If it's a laptop, try running it on battery alone (take out the mains power cord). My laptop has this kind of noise in speakers when running on mains electrical supply, but it goes away like magic when I run it on battery.
A more long-term solution is to buy a 'Ground Loop Isolator' and insert it between your computer and the speakers/earphones. They are quite cheap and you could get it for under £10. It removes all static noise and you'll hear crystal clear sound.
Posted on Jan 01, 2009
  • 32 Answers
SOURCE: Crackling seems to be coming from central speaker
in mu experience its a problem with voltage of your speaker.
did you tried before touching the speakers hard...
because the magnetic in the central of the speaker may damaged.
Posted on Aug 26, 2009
SOURCE: Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Posted on Jan 21, 2010
BlackBerry tablet making funny noises. Sounds like static every time I type a letter. Also
1) try reinstalling the sound drivers of your tablet
2) the speakers might be worn and in this case you might change your tablet speakers if worse come to shove
Mar 15, 2014 | RIM Blackberry Playbook with 64GB Internal...
Iriver clix gets static-y after a few minutes
Hello Cart, I am sorry to hear that your Iriver Clix Gen 2 4 gb video player recieves enormous amounts of static that makes it unaudible after a couple minutes. I see that you have eliminated one of the factors of static by upgrading the firmware, but unfortunately the firmware is only related to booting up, and loading your movies/music. If the static is coming from the speakers, you may not be able to fix it, unless you open up your Iriver Clix, which I recommend you not do, due to that it will void your warranty. The Static may be caused due to excessive geforce or impact to your device, causing the wire's to be loose. If the static is coming from the speakers, I would recommend you to return it to the manufactuer or return it back to the store. If the static is coming from the 3.5 mm plug, try a different pair of headphones or earbuds, make sure it is fully plugged in, I would also recommend you to return back to the manufacturer, or return it back to the store. -Tom Smith.
Aug 26, 2007 | iRiver Clix Digital Media Player
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
I set up my RX-V365 recently, and the center speaker doesnt seem to work. i use it for listening to music, the sound should come out right?
Sound from a speaker, nah, that's an optional feature (kidding).
If you dig into the manual annd go through the setup using the test tones you can prove/disprove the viability of all the speakers and channels. THAT is required before we try to listen to 'music' (assumed 2-channel) on multiple speakers.
Sound Field programs (page 25) can be applied to just about any source. Experiment, even within a given recording. You'll be amazed how different digital processes can make even familiar recordings new and more interesting. I've discovered instruments and sounds in old recording I never noticed before.
Jun 22, 2011 | Yamaha Rx-v365 A/V Home Theater Receiver
Continuous crackling coming come speakers AND headphones while i am trying to listen to music...very frustrating
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the SOUND CARD and the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 03, 2011 | Computers & Internet
Basically, I've noticed a fairly faint static noise while listening to music at about 30%-40& with the Logitech z-2300's. I dont know if the problem persists when the speakers are any higher because I...
Most speakers I have owned or listened too have a faint buzz or static to them. If you are using a computer turn up the volume on the computer all the way and then you should not have to turn the volume knob on your speakers past 20% that's what i did with mine and they sound fine. If you are using something else like an i pod or something like that make sure you turn the volume on the device all the way up to ensure you don't have to turn the speakers up that high. If that's not your problem then i don't know.
Dec 12, 2010 | Logitech Z-2300 Computer Speakers
My computer speakers have a staticy/scratchy noise coming from them, and it' loud as heck. My speaker just all of a sudden got really noisy. I can only describe it as a static or a scratchy sound. It gets...
Turn off you computer and pull out your sound card if it is external. Then plug it back in the same hole. It may just be loose. If this does not help try another card. If you have a built in sound card try installing updated drivers for it from the manufacturers web site.
Dec 11, 2010 | Computers & Internet
Loud static sound comes from computer speakers and the phone
Uninstall and reinstall new drivers for your sound card from the soundcard manufactures website or if its onboards from the PC makers site. If your using vista their has been widespread issue's related to the static "bug" and numerous solutions that sometimes work or do not work have been tried. ex; if is a soundblaster card try Creative.com's forums.
Apr 16, 2009 | Altec Lansing VS2221 Computer Speakers
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
Static noise coming from interior rear by speakers
CHECK REAR AMPLIFIER (INSIDE TRUNK) BAD CAPACITOR OR BAD CONNECTION. REPAIRED MINE TODAY.
COST $30.00-
Jan 08, 2009 | 2003 Jaguar S-Type
Dell Inspiron 15R Laptop Computer (Intel CORE I5 GB4GB) (dndor34b) PC Notebook Logo
37 people viewed this question
Alun Cox
